Question about Magic Chef Dryers
I have a Magic Chef Compact dryer, MCSDRY1S, it runs and stops every few minutes.
  • 409 Answers
SOURCE: magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Posted on Sep 30, 2008
  • 61 Answers
SOURCE: dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
  • 72 Answers
SOURCE: Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
Posted on Jun 15, 2009
SOURCE: Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Posted on Sep 12, 2009
  • 27 Answers
SOURCE: Wine fridge stopped cooling. Just clicks every
its the ptc relay go to in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Posted on Aug 07, 2010
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to 1206838
Jul 21, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler model mcwc16mcg justs keeping clicking not cold anymore , can this be fixed
A clicking sound every few minutes usually means the compressor is going off on overload when trying to start. This could mean the start parts are bad, or the compressor went bad.
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Dryers Logo
47 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
