Hey I have a samsung plasma 63 "Professional Model P63FP-2 TYEP NO PH63KFR The plasma is not lit Even the power light has changed the doubt and is not yet on. Your help thanks
2 Suggested Answers
ideaal
  • 1894 Answers
SOURCE: how do i fix
Most caused by deformed capacitor / or faltering resistor problems.
bulged because of the to tight tolerance in power voltage and resistors in priority the green colored 3 watt type resistors can have thermical faltering.
Posted on Mar 06, 2016
Samsung plasma tv will not power up
Power supply...Plasma Tv's generate a lot of heat..causing the electolytic capacitors to dry out and become defective. If you are a tech you can change the caps..if not then you can probably find the power supply board at ShopJimmy.com
Jul 22, 2017 | Samsung Televison & Video
How do i fix
Mar 06, 2016 | Samsung Televison & Video
HPS6373x/XAA Power issue
Needless to say, it's probably not a blown capacitor. If the unit will not power on at all (control/standby indicators are not lit) the problem may be as simple as a blown fuse on your SMPS (near the AC socket) or on your Main Logic PCB. You should also use your fluke/voltmeter to verify that the Vs, Va, Vsc, and Ve values are reasonably close to those specified on the panel label. Re-post your findings!
Dec 16, 2013 | Samsung HP-S6373 63 in. Plasma Television
FP-t6374 Samsung plasma. Half the screen goes black. Usually the top, sometimes the bottom. Only happens in Summer. Is the tuner board overheating? Do I Cool TV? or should I replace
Sound like a issue with the upper and lower Y buffer boards. It could simply be a connection issue. I'd say the set is worth having it looked at by a professional. A 63" set is worth putting some money into as long as the repairs are no more than 50% of the cost of a new set of similar size.
Oct 12, 2013 | Samsung FPT6374 63 in. Plasma TV
Samsung tv wont turn on
simply change the fuse by its own,,if it wont turn on by replacing the fuse try to test the switch power ,,that would be the last problem so your tv wont turn on
Sep 18, 2013 | Samsung 63" Plasma Samsungs FP-T6374
Pn63c8000 samsung loud pop then no picture. Replaced power supply board. Now I have a little led pilot light lit and very slowly flashing on the logic board.When I turn it off I get a small vertical light...
Replacing main power supply to Plasma displays is not an easy job as you thinks. There are so many adjustments should be done after replacement. If you wish to get more details about these, check this link. Pull up older posts there. Details with illustrations can be seen there.
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 07, 2013 | Samsung 63 PN63C8000 3D Plasma TV
Samsung PS-63P71FH top half switching off
the buffer board in one side has problem.
Aug 15, 2012 | Samsung P63FP 63" Plasma TV
My plasma samsung ppm63mf7: no power, all caps OK, ceramic fuses OK, I replace a failed sustainer board. Now power just clicks and blinking power light\r\nSo I unpluged T-con board and Main board to check...
I had a similar problem with mine, i had to change couple of caps but it still would not power on. I ordered one online and it seemed to solve the problem. the power supply board for the TV are a bit expensive but this guys over at had one for under 200 dollars, http://myoemparts.com/power-supply-boards/53-bn96-03736a-pspf771f01a-power-supply.html
Jun 22, 2011 | Samsung PPM63M7F 63 in. Plasma TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
