Question about HP Office Equipment & Supplies
Need HP Printer 8600 to recognize laptops. Will not print wireless.
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
SOURCE: HP Photosmart 2710 is not recognized over wireless connection
light it on fire
Posted on Dec 08, 2008
  • 16 Answers
SOURCE: printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Posted on Aug 10, 2009
darkpain
  • 316 Answers
SOURCE: How do I print wirless on a HP Officejet H470b
Hello my friend.First you must install the software if you haven't.Insert the Starter CD that was with your printer into the CD drive,the menu runs automatically,if its not double-click the Setup icon on the
Starter CD.On the menu, click the button for the connection method you want to use(wireless).Follow the onscreen instructions to complete the software installation.
After that we are going to create a wireless profile.
Open the configuration utility for your computer’s wireless network card, then do
the following:
Create a new wireless profile with the following values:
• Communication mode: ad hoc
• Network name (SSID): hpsetup
• Security (encryption): disabled
Activate the profile.
Wait two minutes for the device to obtain an IP address, then print a wireless
configuration page.
On the configuration page, verify the following for the device’s network settings:
• The IP address is not 0.0.0.0
Posted on Feb 08, 2010
jbutler9
  • 132 Answers
SOURCE: Cannot connect to wireless printer, pc is connected to 54g direct
You will have to either add the printer through the Add printer Wizard and do a search for a newtork printer
Your best bet would be to install the Software that came with your HP printer on your laptop...at some point you should be given options to find and connect to a network printer.
Don;t forget to Rate/Vote
Posted on Apr 24, 2010
How do I delete eprint?
Usually for HP printers not being recognized because they loose their IP address on the network or the computer can't see it.
What you can do is completley uninstall the HP software for the Officejet 8600, then go to HP.com lookup the officejet 8600 under Support > Download Drivers. download the latest full installation then run the install. When it ask you how to install it do the custom install and then only select the things you want to install.
When it ask you to do the eprint set up you can skip that part. also once install try running the HP updates for find any Network fixes or and Firmware updates.
HP Officejet Pro 8600 All in One Printer N911a Software and Drivers
Aug 06, 2015 | HP CM749A - Officejet Pro 8600...
Why did my 8600 stop printing color over the local network all of a sudden?
Perhaps it is a matter of term use... "printing copies over my wireless network" has nothing to do with placing a photo on the glass and receiving a print. If you have a document on your phone or pad, AND if you have them sycn'd to your WIFI network, you can print all day over your network. Just means you do not need wires hooked up to the printer to have a file printed.
Sep 12, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
I keep getting a printer jam error for the hp officejet 8500 wireless, no paper jam, have done everything HP suggests and still won't work. Can anyone suggest what to do other than buy a new printer?
Hi
This is a coomon problem with the printer the best thing to do is call HP and advise them of the issue. I recently had a customer who did this and even know it was out of warranty they replaced the printer.
Thanks
Daniel
HP Technician
Nov 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I want to print wirelessly from my laptop
the printer has to be a wireless printer. if it is then laptop should recognize it. did it come with a cd to install
Apr 16, 2009 | HP Photosmart C7280 Laser Printer
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
