Question about In Office Equipment & Supplies
How do i clear P-21 And P-5 in Bizhub C203 and what is the cause of this codes
  • 16 Answers
SOURCE: bizhub c203 cannot scan not enough disk space
The Konica technician is going to haveto come out and empty the hard drive on the unit. As a user you can not get to theat menu.
Posted on Sep 03, 2009
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Bizhubman
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
  • 118 Answers
SOURCE: how do i set my KonicaMinolta bizhub C203 to copy
set the copier on black then go to utility/counter, user settings then set current settings
Posted on Oct 16, 2011
  • 118 Answers
SOURCE: how do i replace the
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
Nov 29, 2016 | Konica Minolta Bizhub c203 Copier
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
How to repair c203 bizhub error code 5370
Cooling Fan FM-6 for the MFP board, rear of machine a small fan between to large fans.
filter clean?
DUST?
May 09, 2014 | Genuine Konica Minolta Konica Bizhub...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code c3201 bizhub c203
Fusing motor failure to turn remove the fusing unit. Check for proper operation. If the orange rollers are chewed up replace the fuser unit
try this place for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Aug 02, 2012 | Konica Minolta Bizhub C203
I got an error code 2556 on my c203.please help
Very very common issue... did you clear it yet?? if not to clear it open and close frount door. then to fix issue change toner.... if that doesnt do it try running something with lots of yellow on it... the code means there is too much yellow toner in the image unit... if that wont work then replace yellow image unit.OH you may want to clean the belt sencors too its super easy i can help if needed
Sep 21, 2011 | Konica Minolta Bizhub c203 Copier
What do i do on a bizhub c203 for a c4353 code
There is a problem with the start of scan position this can be fixed with firmware
Jan 31, 2011 | Konica Minolta Bizhub c203 Copier
Error code P-6 and P-21
i have this problem too, how can we solve this?
Dec 07, 2010 | Konica Minolta Bizhub c203 Copier
My konica minolta bizhub c203 will not send out faxes ng error code
you cannot have a VOIP line or FOIP line (like comcast or Vanige) it can only use a dedicated land line. i know this is aggrivating...
Nov 09, 2010 | Konica Minolta Bizhub c203 Copier
32 people viewed this question
Top In Office Equipment & Supplies Experts
bobwin
J.D. Browning
J.D. Browning
roeb
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
