Question about Garden
Center blade shaft assy for pull behind model no t1260pf
  • 246 Answers
SOURCE: r\r the pull rope spring assy
Hello:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
The Following is a "General" "Chainsaw Clutch Removal" File. **To Hold the Crankshaft for Removal of the Clutch; Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 1114 Answers
SOURCE: cannot remove blades for sharpening
Spray the blade/shaft top and bottom with WD40, etc.,and let soak for awhile. Take a pipe wrench, as large as you can get under the deck, and place on edge of blade about 4 inches from shaft. Use the wrench as a fulcrum to pivot the blade off. If needed do both sides of blade until it lets loose. Hope this helps...
Posted on Jul 05, 2009
  • 396 Answers
SOURCE: trying to remove the center nut on the blade holder assy
Very few lawn tractors use reverse threads; however, if a long time elapses between removal, the nut and the bolt can get rusty. This can make it very difficult to remove the nut.
You need to block off the blade so it can't turn. Use a piece of wood lodged between the deck and the blade. Then get a breaker bar or piece of pipe to add to your wrench to give you more leverage. Even with a long breaker bar, there have been times I would have to hammer on the breaker bar to get one of these nuts loose.
Posted on Oct 18, 2009
SOURCE: Have a Craftsman 10" Model 113.241691 table saw
I have the same table saw. Mine has done that for the past 25 years and I've always considered that it's just the flexible shaft coming up to speed. It's never given me any problems so haven't looked into any further.
Posted on Jan 03, 2011
  • 2509 Answers
SOURCE: need to know how to
There is an exploded diagram here which should show how it dismantles
http://parts.robotcoupe.net/mp450.html
Not sure where you are geographically but hope that helps.
You can buy the bearings, I  was going to suggest that it wasn't worth repairing and then I checked the price of a new one!!!!  It is worth repairing I can't believe how expensive they are! Good Luck
Posted on Jan 12, 2011
What is Konica C6500 bizhub PGC sensor?
OK you going to open front door pull out mid section not where the paper is but where the drums and transfer belt are located. Once out go the right and look in DO NOT PUT ANY WEIGHT WHAT SO EVER ON ANY OF THE FOUR SHAFTS you will do some SERIOUS Damage!!!!!!!!!!!!!!!!!!!!!! So looking in there to the left you will see a assy. that is high up even with belt on the other side. That assy. as Three sensors one is your PGC two of thee sensor are in the front one sensor is in the back be care each has small spring that is used to pull the shutter down after the solenoid fires behind that assy. recommended that all three sensors be cleaned they get covered with toner from the belt cleaning assy. That hole assy. can come out to screws in the rear and one connector use a magnetic screwdriver and ensure power is off AGAIN NO PRESSURE ON THE DRUM SHAFTS!
Aug 07, 2014 | Konica Minolta bizhub Office Equipment &...
Coad sc45-20
OK! First this is for a Bizhub C-500 or CF8050 or CF5000 right?
First open the front, then remove the Middle section. Then looking in from the right side(USE FLASH light) (DO NOT SHINE THE FLASH LIGHT ON THE DRUMS. DO NOT PUT ANY PRESSURE ON ANY OF THE four SHAFTS DO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!NOT!!!!!!
you will see a 2"x6" assy. which monitors the transfer belt this assy. has three Sensors on it each covered by a metal covering which solenoid operated. Well the sensors behind the covers get toner on them they need to be clean with a DRY rag you have to raise each cover be careful not to have the springs (which pull the covers down after the solenoid open them. fall in side the machine, not good. HAVE to be flex able to get in there again do NOT Apply any pressure on those shaft you asking for problems big time. if that does not work mite need to replace the assy. OR have the Transfer belt replaced and belt Cleaning blade assy.
Apr 29, 2014 | Minolta Office Equipment & Supplies
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
The blade on my Delta Model 36-075 miter saw spins freely - motor works fine - i disassembled down to the gear drive - the gear appears to be fine no missing teeth or obvious damage. Does the inner shaft...
hi, on your Delta saw shaft has two flanges which one goes in front of the blade and the other behind the blade. These flanges have two flat spots in the center of it which over the shaft, the blade has the same cut out so you need to check your shaft, flanges and blade to make sure they are all locking on the shaft. Do not forget to unplug the saw before you do any work.
Feb 09, 2018 | Delta Saws
Guard
I'm not certain this is the same model I'm thinking of, but I think there may be a knob on the back side (behind the blade) which clamps down on a shaft coming off the blade guard. Loosen the know and the guard should pull straight off. Maybe I'm thinking of a different model slicer, but the photo looks correct.
May 19, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
After my daughter mowed awhile when i went out the pull cord was stuck and i can't start it
The drive shaft probably just needs to be lubricated. When you pull on the pull cord it turns the blade, so if the shaft that the blade is attached to won't turn, the cord won't pull.
If you turn your mower over and look at the shaft that runs up into the mower from the center of the blade, you can squirt some oil up into where the shaft disappears inside the body of the mower. Use a generous amount, and then turn the blade by hand (carefully so you don't cut yourself!) and squirt some more oil. The blade should get easier to turn, and once it's as easy as you think it's going to get, try pulling on the cord and it should pull with no problem.
May 02, 2010 | Poulan Pro " Pro" Self Propelled Mower
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
How do i clean the iris blades?
This is for Sanyo VPC-HD1, VPC-HD1A black screen problem how to clean auto iris unit.First you have take apart camera : remove 4 screws from right side (in battery compartment) 2 screws from bottom, 2 screws from top (there are different short one is from rear) and last screw from front, now pull left cabinet from top and take appart.Be carefull !!! there is flash capacitor you need to discharge it before doing anything else.You can discharge with  1Kom 5watt resistor . After that remove 1 screw holding speaker, disconnect and remove speaker.Now pull power board PW-1 there is a screw holding lense ring remove that screw, disconnect 2 connectors from lense assy (from ccd just pull, from lense unlock and pull flat cable now you can remove lens assy. Next remove 3 small screws holding heat sink (rear of lens assy) after that remove spacer (black tape from top of lense and another small tape at rear top of lense. Now you can see 7 white screws and 1 black screw remove all of them.Black screw holding iris unit.Now carefully lift zoom motor focus motor 2 sensors nd filter assy and iris unit they came out all together.Next thing main thing you have to open iris unit it is easy to do with sharp blade on the edge of iris unit you will find 2 locks holding  metall casing of iris unit put blade between metal and plastic case and pry to remove metall case. Now you will find iris 2 blades there are different you need to remember wich is wich.Now carefully remove both blades (they might stick to each other because of grease) and place them into isoprophyl alcohol after that put them on to napkin fold napkin so blades are inside and dry them you also need to clean iris unit where blades are going from grease and also clean zoom motor and focus motor shafts to remove grease. Now put everything back together and i hope you can do that. Good luck.
Aug 17, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
Planetary shaft for h600 is bent
Thats the center shaft and if it moves back and forth the lower bearing is bad or the shaft has cracked.You need to remove all 3 shaft assemblys. if you already removed the gears on the center shaft then you need to remove the shifting yoke---turn power off to machine then take the screws off the trim plate where you shift speeds,you might see a switch that sits up on the shifter cam,remove the screws and put switch aside,take the 4 allen screws off and pull on the shifter(it will come out).If you didnt already drain the oil do it before you mess with the shifter.after the shifter is out grab the upper left gear assy. and the gear assy. below it,rock both gear assy. and pull up,they will both come out(you might need some force)once out remove the remaining gears on the center shaft and remove the shifting yokes.you then need to remove the planetary (lower part of mixer)if not already done,then pull the shaft out from the bottom.any questions let me know.
Nov 19, 2007 | Hobart D300 Stand Mixer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
