Question about Water Heaters
Can you please send me the list of recommended retired people who do jobs around the house and garden. It was in one of your booklets you sent out from Colchester Borough Council.
I am looking for a plumber and home help. Thank you Angela Dearsley Colchester
My Whirlpool Energy Smart Water Heater, Model ES50R92-45D will not unlock after holding the lock button for 3 seconds or longer???
A button any remote should only be pressed once, unless another function is available. By keeping the button in, it may go into another mode. The golden rule is to press the button firmly and only for a short period. When a remote does not do its job of sending the signal, people tend to press harder. This practice aggravates the problem, which normally is a flat battery.
Oct 08, 2017 | Water Heaters
Sand in water
It sounds like the pocket developed for your wellpoint has collapsed. In order to redevelop it, you must pump water down into the well pipe for some time. I'm not sure how long. This opens up a pocket for your point so that it has no contact with sand. Of course, everything else must be flushed to remove the sand from your entire system. Goos luck!
Apr 08, 2017 | Amtrol WX-202 WELL-X-TROL Water System...
Water heater makes bubbling sound
If your tank is very old than there might be accumulation of rust and debris on bottom of tank, try and purge the tank put a garden hose on the lower most water fitting at the bottom of your unit and drain the tank. Be sure to shut off the water inlet. You might even have the booklet still taped to the side of your unit and it will explain how to flush your unit.You might also want tot think about replacing your anode rod it is probably toast if old unit.
Nov 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a whole house water filter that uses a 30 micron FXHSC filter. the last two filters have come apart and sent fiber through the water lines in the house
I would shop around for a different water filter supplier...there is no reason ofr that happening unless you are not changing the filters once a month...
most filters are a standard size and it should be easy to get them somewhere else...
Aug 13, 2010 | General Electric GE SmartWater Household...
Can I reduce hose size from 1- 1/4 to a 5/8 garden
The short answer is no.
You will not get any flow and wreck the pump.
Go to a Home Depot, Lowe's or Plumbing Supply House and get a 100' roll of black Poly Pipe and roll that out over the ground. The check also has to be at the end of the pipe and the pipe shoud slop away from the pump if possible. This will make it much easier to prime the pump. Air will cause the pump to lose it's prime so you want to get all of th air possible out of the pipe before starting the pump.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 05, 2009 | Water Heaters
My electric water heater tank just started shooting water out of the pop-off valve. I turn of the water ''ALL CLEAR- PLBG AND CLEANING'' LEVER and it stopped for now. In turn, water started leaking from...
Sounds like the thermostat is bad and it is over heating. So please turn the power off till you can look at it. If it stays liek this and that is the problem you can kill someone and also blow your house up.
Mar 27, 2009 | Water Heaters
Water Heaters Logo
67 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
