Question about Garden
Pto will not engage
My lawn tractor will start and run but the cutting deck will not engage
riceski
  • 1851 Answers
SOURCE: my lt150 lawn tractor is backfiring when the pto
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
Posted on Jul 22, 2010
mickey813
  • 472 Answers
SOURCE: GTH2548 drive spring broke and I replaced it.
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Posted on Sep 08, 2010
  • 407 Answers
SOURCE: My Husqvarna lawn tractor deck will not engage
First check the belt.Make sure it is tight when the lever is engaged,and the engine is off.Make sure the belt is on all pulleys,and inspect for frays in the belt.If the belt is ok then,run your hand under the fender around the area of the lever.Make sure there is no debris blocking the lever from fully engaging.If that is good.Next inspect the linkage between the lever`s handle and the deck.Again make sure there is no debris and all connections are snug.
Posted on May 16, 2011
  • 153 Answers
SOURCE: My Craftsman Lawn Tractor is
it sounds like the deck and or the belt needs to be adjusted and aligned. 1st make sure mower is OFF and blades are disengaged. check to make sure the deck/blades are free of harden grass, twigs, branches, and that they are free moving. 2nd make sure belt is in its correct path. 3rd make sure the deck can be lowered and raised without obstructions 4th make sure no parts have been bent and the pulleys are parallel to the deck and the deck is not cracked or broken by the blades hitting something hard and the deck being damaged. 5th the belt adjustment needs to be tight but not over tightened (see a service dealer).
hope this has been helpful. contact me if you need further help.
Thank you.
Posted on Jun 26, 2011
SOURCE: every time I am running my murray lawn tractor i
have a 13.5 hp tecumseh ohv formula riding mower. when engage blade for cutting white smoke comes out of front of engine. is the motor blown? can it be fixed or cheaper to replace?
Posted on Jul 27, 2011
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
My pto engages on the highest level for my deck on my mtd lawn tractor. Highest my deck will go is 5. But when I put it to 4 ir even 3 the pto cuts out. But as soon as you return it to 5 it starts
Owner's manual? no manual, try for both owner and Repair manual on manualslib.com
Wild guess, the angle of the PTO drive shaft related to the height of the deck is causing a problem. Perhaps it's binding and won't turn, or pops out because of the binding and load. Perhaps the drive shaft is not "locked" on for some reason, with pins or
another device. Perhaps the sliding portion needs lubrication.
Apr 06, 2015 | Mtd Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt. came off... pulling up blade engagement knob nothing seems to happen.....I have trackter up on blocks with blade cutting height at 1 with engine runnig the blade engagement knob switch ...
sounds like a bad PTO, that is the electrical gizmo on the bottom of the engine's driveshaft which engages the bottom pulley, running the deck. you might luck out and find the fuse is blown so follow the wire from the PTO back until you find the fat part in the wire. the fat part is an in line fuse holder with a fuse in it. if the fuse is bad and blows again, you need a new PTO
Aug 19, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Jun 08, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
