Vestel tv not turning - Televison & Video
Code vestel tv
1061 1052 1423 1051 1007 1032 1012 1177 1145. These are the codes to check with Vestel. If you wish to get more, http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide / Flipcard option.
Aug 02, 2013 | Directv Universal Remote
Tip
Vestel DVD4250D Service Manual Download
Download Vestel DVD4250D Divx DVD Player Service Manual
Have you misplaced your Vestel DVD4250D Divx DVD Player Service Manual?
Would you like a digital, searchable, pdf version of the Vestel DVD4250D Divx DVD Player Service Manual?
Follow this link (& click FREE) to download a pdf version of the Vestel DVD4250D Divx DVD Player Service Manual.
I hope that helps.
____________________________________
on May 03, 2010 | Televison & Video
Tip
Vestel DVD4500D Service Manual Download
Download Vestel DVD4500D Divx DVD Player Service Manual
Have you misplaced your Vestel DVD4500D Divx DVD Player Service Manual?
Would you like a digital, searchable, pdf version of the Vestel DVD4500D Divx DVD Player Service Manual?
Follow this link (& click FREE) to download a pdf version of the Vestel DVD4500D Divx DVD Player Service Manual.
I hope that helps.
Comet hitachi tv loses tuning / untunes everytime switched off
Vestel make the power boards... its unlikely that they will help. Your best bet is ebay, look for 'main board'
Aug 28, 2017 | Televison & Video
TV CODES FOR VESTEL T845 REMOTE
go please to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jun 22, 2012 | Televison & Video
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Aug 13, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Cannot programme black diamond television.
Your universal remote control will only give you ch +/-,Vol.+/- and mute it will not give tuning or picture controls ie brightness, colour, zoom, the Blackdiamond are usually of Vestel make try searching for Bush,Vestel,Goodmans or try the search for code unknown in the remotes instructions it will operate the TV but please read the instructions carefully.
SUPER8
Nov 21, 2008 | Televison & Video
Red stanby light flashing and wont turn on. Model is hitachi tv l42vp01u. Any idea? Thanks
Mine has just done the same and the power board has been taken away by tv tech for repair, seems the power board on these vestel/hitachi tv's are not very good. Fourth one I have learned about. Stoots
Jul 31, 2008 | Televison & Video
Wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
audiovservices@fsmail.net
Apr 18, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
