Question about Boss Car Audio & Video
Need To Know How To Hook-Up A Boss AVA 1404 EQ to my Radio
I have an 89 Buick LeSabre,I need to know how to hook-up my Boss AVA 1404 EQ to it.It is an aftermath brand radio with AM/FM?CD player also with an MP3 connection.I need detail instruction on how to do this without screwing up or burning anything up.PLEASE help me.
  • 14 Answers
SOURCE: Do I connect to the high or the low input
someones stereos...?ldies....dont have pin jacks(low impedance)..if you stereo have it make this conection because is more eficient and have low distortion.....good loock.
Posted on Feb 09, 2007
SOURCE: HOOKING UP???
An eq has to plug into and amplifier so if you only have 1 amp, you go from the rca output from your deck into the eq, then into your amp. The power you should be able to parallel right from the remote, 12+, and ground from the amp. Your eq will only equalize your subwoofer unless your mids and highs were hooked up to amplifiers too. If this helps, be sure to leave me good feedback. Dan
Posted on Sep 17, 2007
SOURCE: how can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Posted on Dec 07, 2007
Schrody
  • 17 Answers
SOURCE: PACKARD BELL CD/RADIO/MP3 PLAYER. MODEL PB OP 10
This is not for connecting an MP3 player, but rather for playing MP3-CD's. Using your computer and a CD burner, you can burn a CD with up to about ten hours worth of MP3s on it. The procedure for creating the disc varies depending on your burning software. In Nero, for example, you would select "Music" and then "MP3 Disc" and then select the songs you want to put on the disc. For other software you just select "burn a data disc" and then select the MP3 files you want.
Once you have a CD full of MP3s, put it in the Packard-Bell stereo's CD player, and you will be able to play all the MP3 files that are on the CD. THe advantage, of course, is being able to put ten hours on one CD instead of only 80 minutes.
Posted on Feb 14, 2008
  • 59 Answers
SOURCE: 2000 silverado radio problem
you can an adapter plate may be needed depending on the style indash radio you pick and an accessible changer mounting location needs to be located prior to installation.
Posted on Nov 07, 2008
How to install Boss audio systems AVA 1210
I tried to install my boss Ava 1210-7 equalizer but I have a 2din001 radio i have a rca jack plug at the back of the radio say AV in its 3 jacks red,white and yellow. I only connect a rca jack to the red and white and leave out the yellow one when I put that to my EQ CD rca section it doesn't work I don't know what to do next! Can someone help Out?
The picture is the rca jack section from the back of my radio
Mar 05, 2012 | Boss Car Audio & Video
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
Whats the red wire is it constant power? When I ground it can I put it to the radio ground?
You should have a yellow wire that is constant, and the red is for the ignition. It's what signals the EQ to turn on. You can hook the ground up to the radio ground. It's not advisable to do it that way, but you can. The reason why it's not a good idea is because you should use a bigger wire when you connect two smaller wires. Most wires behind the radio are about 16 gauge. Using bigger wire number sizes for an amp as an example, you could use a four gauge wire to a distribution block. From there you would use two eight gauge wires to go directly to the amps. This helps electricity travel the path of least resistance. It does not matter so much on smaller wires.
Apr 13, 2011 | Boss AVA-1208S 4-Band Equalizer Car...
I dont know where to put the remote wire
If you have an aftermarket stereo you can hook it up to the antenna wire usually blue/white or just blue color if is not an after market I need to know the car year/make/model.
Jan 20, 2011 | Boss AVA-1215 5-Band Car Equalizer
Need to hook up an amplifier to a stock 2000 Buick Lesabre radio, do you have a manual?
In order to hook up an after market amplifier to a stock stereo your going to have to use a line output converter to adapt it to RCA cables to hook up to your amplifier.
Oct 14, 2009 | 2000 Buick LeSabre
I need to know where to hook up the vacuum lines under the dash of my 1990 buick lesabre.there are three hoses hanging down under the dash, three different colors. and my heater control doesn't change the...
Snap bezel around heater controls off. Small black rectangle. Remove screws underneath. Remove trim that goes over to radio. Now remove the screws to the ac controls and pull it out to reconnect hoses.
Mar 28, 2009 | 1990 Buick LeSabre
No clue how to connect my equalizer
FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
Jan 13, 2007 | Boss AVA-1404 7-Band Car Equalizer
Car Audio & Video Logo
80 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
