Question about Microwave Ovens
What can can a microwave to cut fuse - Microwave Ovens
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
MICROWAVE OVEN "DAEWOO" MODEL KQG-868G PROBLEM :
There should be 3 'fuses' inside a microwave. The 'line' or monitor fuse, the magnetron fuse or TCO (thermal cut out) and the cavity temp fuse. I'm trusting that you have verified that the outlet is 'hot' first. Be careful !!
Nov 03, 2013 | Microwave Ovens
Microwave has no power
Besides the regular fuse your microwave has two thermal fuses - one is attached to the magnetron tube (called the magnetron Thermal Cut Off or TCO) and the cavity TCO (usually located under the air ducts on the left side of the microwave). If you have the wiring diagram (usually supplied with the microwave) you can find them there. Unfortunately the model number you provided is incomplete and I'm not able to find the wiring diagram for your microwave.
garden led light
May 21, 2012 | Microwave Ovens
Where is the high voltage fuse on a microwave
The thermal fuse monitors the magnetron temperature and cuts power, if it gets to hot and resets in no more than 20 to 30 minutes. Unplug microwave oven, remove top, "several screws" look over to the right, thermal fuse is mounted on top on the inner chassis, "round and thick with 2 wires clipped on"
Apr 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
My Panasonic Microwave NN-T573SBBPQ cuts out after 3 seconds. what can I do? Or am I better of replacing it?
This sounds like a magnetron problem, if it gets to hot, there is a special thermal fuse that will open up if it senses abnormal temperature rise from the magnetron and after a cool down period it will reset itself. In rare cases I have known the thermal fuse to become defective and cut out prematurely. My feeling is replace the oven! because by the time you get a appliance repairman in for a sevice call and parts you probably could have bought a new microwave oven.
Jan 19, 2011 | Panasonic NN-T990SA Microwave Oven
The problem of my microwave panasonic, i flug the socuit then ok,i put one minits then i start but the fuse inside the microwave cut off then i change the new fuse but still cut off what is the sulution...
I would call an approved Panasonic repair shop, as there is a possiblity that the invertor is faulty and that requires specialist equipment to repair it.
Jan 12, 2011 | Panasonic NN-S960WA Microwave Oven
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I cant turn the microwave oven on without the fuse cutting out
If you got the interior of the unit wet you may just wait a couple of days for it to dry out and it will be ok again. You may also plug your microwave in to another outlet, one that still works when the fuse that blows is unscrewed.
Finally you have a 1000 watt microwave which translates to using 10 amps of power. If you have a 15 amp circuit, looking at the number on the fuse, and you have other things plugged into that circuit like a toaster, toaster oven, coffee pot, hair blow dryer, etc, you may simply have to unplug something else to provide your microwave with the power it needs. good luck.
Aug 16, 2009 | Daewoo KOC-925T Microwave Oven
Sick Microware
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
Feb 05, 2008 | Bosch HMT8625GB Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
