Question about Kenmore Washing Machines
I have a KENMORE 90 Series Heavy Duty Super Capacity Plus Model# 110.20922990 that will not agitate. It fills and drains perfectly, but agitate and spin cycles don't work. Basket only spins during rinse/drain. After filling the machine just starts clicking noises while set knob counts down time. Suggestions?
  • johnmothersh Jul 29, 2009
    Replaced Motor Coupling and that did not work. Machine acts the same. Coupling was in perfect condition - no cracks or other signs of wear.
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
244 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
