Question about Westinghouse Televison & Video
My 55 inch westinghouse tv menu keeps popping up while I am watching tv, yes took the batteries out the remote still dosen' work and the volume not working right only had it 5 yrs.
premtech
  • 934 Answers
SOURCE: HDTV 52 INCH RCA
It could be a failing tac switch or the micro. The only way to tell is signal trace the switch circuit with a 20mhz scope.. Need a shop for that if you don't have the equipment and it's not terribly expensive...
Footnote: either failure can and usually will get worse over time and may infect other function, vol,ch, power and so on... Find a reputable shop and take it in.. If you have any problem location one let me know..
Bill
Posted on Dec 11, 2007
  • 668 Answers
SOURCE: My menu keeps popping up tv and my volume dont work
Most of the time this is caused by one or more of the front panel buttons being bad. I would have all of them replaced.
Posted on Jul 16, 2009
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
BoiseLCD
  • 63 Answers
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Posted on Dec 16, 2009
gopakumarg43
  • 75424 Answers
SOURCE: Westinghouse tv on screen settings menu keeps
Check whether its menu button on the TV control panel is jammed.
Posted on May 24, 2013
Is there any way to get rid of the update notification on my Soniq 55 inch smart tv without the remote?
NO IT IS NOT ON THE SIDE OF YOUR TV THERE SHOUD BE SOME BUTTENS ONE OF THEM WILL TAKE YOU INTO MENU WERE YOU CAN GET RID OF THE UPDATE NOTIFICATION
Apr 05, 2016 | Televison & Video
Why does the menu and channel display keeping poping up while watching tv?
1. Remove the batteries from your remote to ensure that is not sending signals to the TV.
2. The TV may have an internal problem and might need repair.
May 11, 2014 | AOC Televison & Video
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
My tv menu keeps popping up every few seconds.
MENU KEEPS POPPING UP WHILE WATCHING A PROGRAM. I REPLACED BATTERIES ON REMOTE CONTROL AND HAVE UN-PLUGGED THE TV SET. I OWN A 42INCH PHILIP PLASAM TV MODEL#42PF9630A-37
Oct 02, 2009 | RCA R61WH76 61" HDTV
THE MENUE KEEPS POPPING UP WATCHING TV.
remote is bugged out has water damage!try unplugging batteries in remote for test!
Feb 26, 2009 | E-Machines eMachines Desktop PC
Control Panel
Yes you can replace the chip, BUT, first try to clean the button contacts. I have to do that to my remotes, phones, and RCA TV (yes I have one too) etc.. around my house. Just needs a good cleaning. Don't forget to unplug the TV.
Jun 30, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
264 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
