Question about The Office Equipment & Supplies
I purchased 2 da lite fast fold screens about a year ago and one of the screens has some serious bleed through from the black material? .
The black marks are imbedded under the white material and won't come clean. What would cause this and is there a way to repair?
  • 275 Answers
Repaiur or replacement? It's Your call! If you know Solid State repairs, then worth a try. Most likely a bad Electrolytic capacitor in the Vertical Oscillator / Output section. Do not waste time identifying faulty one, but change all at one go. Even if one is faulty, the others must have started drying up, and will cause problems in the future.Remember "An Ounce of prevention is better than......"
Posted on Oct 02, 2006
  • 3130 Answers
SOURCE: discolored oval
Open the set and see if there is anything inside the set, like cobwebs, ect. Also look down into the tubes while the set is on to see if there is anything floating around inside the fluid. My educated guess is that it needs cleaning. Good Luck PS Please do not forget to rate this thread
Posted on Dec 07, 2006
  • 3463 Answers
SOURCE: black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Posted on Jan 21, 2009
SOURCE: I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Posted on Sep 03, 2009
  • 2976 Answers
SOURCE: What would cause white residue on plastic?
With the reformulation of detergents, it's becoming a common problem. You can try a liquid with water softener in it, and slightly hotter water. It might help. The environmentalists have made the manufacturers reformulate a lot of cleaning products to the point that, vinegar and water is almost as good as the newer detergents.
Posted on May 12, 2010
I wanna fix my sony bravia lcd kdl 46bx420 myself
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 18, 2014 | Televison & Video
My Laars 2 lite pool heater will not ignite, I have the same problem every year for the first ignition. The pilot is lit. I removed the filter to make sure it is not the pressure.
you might need to bleed the line to get fuel to the heater core. If there is a bubble in the line it will prevent the heater from working. Usually, there is a bleeder valve on the heater unit -- unscrew this and let some of the fuel drain out (into a container) and give it another shot. It should light right up after bleeding the line. If the fuel that you took out of the bleeder valve looks clean, you can then put it back in the fuel tank and it should be fine.
If this is a natural gas heater, there will be no bleeder valve -- you should have it looked at by a professional repair person. Natural gas is very dangerous and should only be repaired by a qualified professional to avoid serious injury or death.
May 27, 2011 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-FoldĀ® Projector...
Screen darkening,automatic restarting,frequently
most of the owner of this phone got the same problem and i'm one of it...
Sony Ericsson need to do something to solve this problem like for example trading phone for another model
Jun 14, 2009 | Sony Ericsson G900 Smartphone
My daughters nintendo ds lite bottom screen will not stop shaking
you recalabrate the screen five times , then tap it gentally on your hand
Jan 22, 2009 | Nintendo DS Lite - Onyx
Da-Lite Cosmopolitan Screen stretch marks
unfortunately, unless you find one on ebay, you might be out of luck. sorry.
Sep 10, 2008 | Da-Lite Picture King w/Keystone Eliminator...
Nintendo DS Lite Touch Screen Fades
You're going to have to send it in for repair. It sounds like it's out of warranty, which is unfortunate.
Dec 05, 2007 | Nintendo DS Console
22 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
