Question about AT&T Blackberry Curve 8300 Smartphone
When I use my phone on my curve 8300 it shuts down.
The only way to get it back is to take out the battery or plug it into the charger. The Curve never blanks out when in the charger.
It it perhaps the battery. The battery is about 3 years old.
    Brigadier General:
  • 7,752 Answers
Try a new battery if that does not work then try reflashing the OS on the phone.
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
Posted on Jan 31, 2010
I have a Blackberry curve. When its plugged into the charger the red light comes and then after a few seconds the screen lights up and something that looks like a lightning bolt comes on to the screen. The...
Chances are either the battery is fried. or the OS is nuked.
Take the battery out, plug the phone in and try to turn it on. If it powers on just fine, it's the battery. If not. The OS is nuked and needs to be replaced.
May 16, 2011 | AT&T Blackberry Curve 8300 Smartphone
My curve is locked in camera mode. My daughter presses "something" and I cant get out of camera or snap a picture to get out of camera or go back to home screen. power down didnt help - help!!
Reflash your blackberry phone, it should be works and will make your blackberry camera curve 8300 unlocked. If that solution not working, bring your phone to nearest mobile phone repair shop and asking them to unlock blackberry using cable unlock. It's not only unlock your camera but also unlock your network if successful.
Mar 06, 2011 | AT&T Blackberry Curve 8300 Smartphone
My blackberry curve 8330 keyboard is locked up. dont know how this happened. ball moves curser up and down on the facepage but will not work when i press the keys. the screen goes black in a few seconds...
the keyboard on the device isnt registering the key clicks because either the keyboard isnt pressing down all the way or the circuit board that the keyboard belongs to is malfunctioning. If it is that, parts for the phone is available on ebay.
Oct 07, 2010 | AT&T Blackberry Curve 8300 Smartphone
My BlackBerry Curve will not turn on. I tried removing the battery. When I plug it into the wall charger the notification light will flash four times. this repeating every few seconds
Hi!... I suggest you have to see a technician with these problem. Most modern phones especially with problems like these needs software reformatting.
Sep 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I just my curve two weeks ago.
Sounds like you got a defective battery if phone was purchased new the return it to get a new battery. I would first try buying a phone charger at Walmart since its easy to return. Hope this helps
Dec 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
Black berry that wont turn on
Remove the back of the phone. Pop out the battery. let it sit for about 10 minutes. Replace the Battery & the back cover of the phone. If the phone starts up, then let it start and immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
If the phone does not start up then do not try to start it just immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
It works for my Blackberry Curve 8310...
Nov 25, 2008 | AT&T Blackberry Curve 8300 Smartphone
8300 will not charge
My charge port is broken out of my 8300. I bought an extra battery and an external charger off of eBay for a little of nothing. You can also by a pod that will charge your Blackberry. The two gold tabs on the back of your device beneath the battery is an external charger connection for a desktop pod.
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
My blackberry curve shut off and will not come back on any clues?
Take out the battery and rub it really fast inbetween your palms, it has not let me down yet, a wierd way, but give it a try,
Sep 03, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
AT&T Blackberry Curve 8300 Smartphone Logo
55 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
