I have a techinical pro rx55uribt receiver display is lighting up but show nothing and there is no sound what can i check
2 Suggested Answers
  • 6702 Answers
SOURCE: How many watts per channel in a technical pro
What is in a Watt.
Although Watt should be a dimension of power (current times Voltage) most manufactures give numbers you can't use. They always speak of maximum power. That number only can be reached in a laboratory and is measured on a clean resistor. They try the lowest resistor (not an impedance) the amplifier can work with, without blowing the end stage.
Then they put a free marge to tell you it should have a musical power of xxxx Watts. The output differs for speakers of 2 ohm, 4 ohm or 8 ohm. But there is not one speaker with an impedance over the whole audio spectrum.
Just read something over audio and power amplifiers.
The output has nothing to do with the quality of the sound. I have heard 15 Watt amplifiers perform hundred times better then some kilowatt amps.
Even if the manufacture says the amp is 1500 w it could be within legal limits and fir the amp is measured and can't deliver 100 watts of real power nobody can do a thing, because the watts could be the musical power. and that is a free invented non measurable measure. I don't even want to start over distortion, because the cheaper amps do produce more distortion, than music. If you use it for a sub woofer that is no problem, because you feel more than you hear.
Sorry for this big story and not saying what the real output is, because nowadays nobody bothers measuring amps like this.
The more serous audio magazines, will put some test about amps, and you should read one or two test to know what I mean about the worth of watts in audio.
Posted on Jul 12, 2014
How do I get the usb play on my technical pro rx55uribt
Plug the usb device into the player and power-down - unplug it.
Replug it with the device plugged in and see if there's a change....
Jul 02, 2016 | Technical Pro RX55URIBT Professional...
Hahnel Giga T Pro II remote function not working
Hi Jack,
I assume you have an answer by now but if not. Cable between receiver and camera is the issue. One of the jacks has 3 black rings on it, which must go into the receiver. The other has 2 black rings and goes into the camera.
regards
Kent
Mar 27, 2013 | Hahnel Giga T Pro Ii Wireless Remote...
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Surrond sound not working
it all depends what digital mode you use ,yes in Pro Logic mode on the display it shows only 1 S but if you try the balance for the SL-SR you will hear the difference .
Feb 03, 2009 | Sony STR-DE675 Receiver
Led display not showing any text
Terry,
Sounds like it might be a motherboard problem...
Hope all is well.
Kev-
Jan 20, 2009 | Epson Stylus Pro 4800 InkJet Printer
HTR 6050 - Digital Sound Changed
I hope you've figured this out by now, but if you haven't...
My guess would be to press the SUR. DECODE button a few times on the Remote and see where that takes you.
Nov 01, 2008 | Yamaha HTR-6030 Receiver
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
29 people viewed this question
 Grubhead
Grubhead
