Question about Garden
Fuel line routing for a polan 446t pole saw - Garden
canbruce75
  • 1776 Answers
SOURCE: I need to change the pull rope on my poulan pole saw 446t
Check out the video at the link I am providing and see if it is what you're looking for. Sure hope so and best wishes.
http://www.youtube.com/watch?v=Zs91D_wln2Q
Posted on Sep 01, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
dontbother10
  • 2220 Answers
SOURCE: I have a Polan Model 2375 Wild Thing Chain Saw.
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 20, 2010
Testimonial: "Thank you for your help. Your instructions were correct.I did have to reverse the connections on the carburetor. My chainsaw works fine now."
hunter19_46m
  • 7482 Answers
SOURCE: replaceing fuel line in polan
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Please take time to rate me thumbs up
Posted on Sep 16, 2011
  • 2239 Answers
SOURCE: need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Posted on Sep 10, 2012
Testimonial: "This description of the line routing seem very complete and should be extremely helpful to my being able to repair the saw. I will try this solution tomorrow. THANK YOU very much. F Sandry "
Polan 3400 fuel line route?
I haven't seen a manual yet that shows you the fuel line route on a piece of equipment.. Generally its the most direct route from tank to carb to primer (if it has one)
May 19, 2016 | Poulan Garden
Need routing gas line
You can't........your using an electric chain saw !
Jun 25, 2014 | McCulloch 10" Electric Pole / Chain Saw
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
I have a Polan Model 2375 Wild Thing Chain Saw. The fuel lines have deterioated and I need to know correct routing of fuel lines. The primer bulb has to line connectors, one small diameter and one large...
Poulan.com
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Sep 01, 2009 | Poulan Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
