Question about The Computers & Internet
Cork is stuck in electric rabbit corkscrew with some of the screw below the cork. is there a way to remove the cork?
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Rubbermaid cork
....................unscrew it!..................
Posted on Jul 22, 2011
A cork is stuck in my rabbet electric wine opener
It automatically ejects the removed cork from corkscrew, if this has not happened then it is faulty!
Jan 08, 2017 | Refrigerators
A cork is stuck in my rabbit electric wine opener.
It automatically ejects removed cork from corkscrew, if this does not happen then it is faulty and needs to be returned under warranty.
Jan 08, 2017 | Home
How do I use the original rabbit
I assume you are talking about the rabbit wine bottle cork remover. here is a you tube video on how to. hope this helps . How To Use The Metrokane Rabbit Corkscrew
Sep 25, 2014 | Vehicle Parts & Accessories
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
What are all the different types of corkscrews?
Waiter style-light and easy to use and move around. Twist the squiggly part into the cork as much as you can and then pull the cork out.
lever style-don't need to be strong. you just squeeze the sides together and pull the corkscrew up and the cork easily comes out.
twist- twist handle and cork comes up. similar to both waiter and lever styles.
pump-inserts co2 and cork pops off right away.
Jan 16, 2013 | Home
Do you have any helpful hints on how to cork a bottle of wine properly?
The most important secret to corking a bottle of wine is to make sure that the corkscrew enters the cork at a straight angle. If it doesn't, it becomes easier for the cork to chip and thereby decreasing the value of your wine.
Jan 10, 2013 | Home
A cork is stuck in my Oster Electric Wine Bottle Opener.. It spins and spins but will not move up or down. How can I fix this?
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Dec 28, 2010 | Sunbeam Oster Electric Wine Bottle Opener
Computers & Internet Logo
104 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
pathfinder51
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
