Question about Frigidaire Refrigerators
Frigidaire GLRSF266J Side by side. Water is pooling on the freezer side in the bottom and at times seeps out the front. What do I do?
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
IFIXALL
  • 868 Answers
SOURCE: GE side by side refrigerator-1994
Check your drain pan for water.If you see none than you have a clogged drain line in the freezer.Remove the back wall lower screws and any screws that will prevent you from getting the back freezer panel off,NOTE : this is in the freezer located on the back wall. You will see the drain behind this panel , if its clogged ,un clog it.
Posted on Aug 18, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Posted on Aug 04, 2009
Frigidaire GLRSF266J Side by side. Water is pooling on the fridge side in the bottom and at times seeps out the front. What do I do?
If water is on the right hand side try turning water supply off if leak stops you Have hole in water reservoir if it's on the freezer side the drain is clogged and can be cleaned out with hot water
Dec 09, 2015 | Refrigerators
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
PLHS267ZA is leaking water from the bottom (freezer side)
I would look under the fridge for a drip pan that might be full, so when it defrost it overflows the pan and runs on the floor. If not that you must have a blockage somewhere in the drain line that runs to the drip pan. Take out the shelves and take off the plastic panels to access the drain and drain line, pour some warm water down the drain to unplug it.
Jan 03, 2014 | Frigidaire PLHS267ZA Side by Side...
GE side by side Model # TFX25PPBAWW Serial # GT257367 Water leaking out the front freezer side. Ice is accumulating at the bottom where water is poolling. I have removed the Ice maker from the freezer...
You have two things causing this
1) the water valve for the i/m is seeping and not fully closing,with the i/m removed no water should come from the tube and the valve should be replaced(alos it were the from the im their would be ice build up from that tube all the way down to the very bottom)
2) this is the most prabable cause with the abense of ice build except at the bottom around the lowest drawer and that is the defrost drain is blocked,the drain can be found at the very bottom of the rear panel of the freezer and is blocked so instead of the defrost water draining it is pooling at the bottom then running out all over the floor
to clear the drain push a wire hanger through the tube till a small hole opens then flush it with hot water
Jul 19, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water from freezer pools at the bottom
The drain line for the evaporator is frozen shut. You have to thaw the drain line that is located behind the rear wall in the freezer side. It is at the very bottom and will require a hair dryer or lots of hot water.
Aug 24, 2009 | Frigidaire FRS26R4A Side by Side...
Side by side refrigerator/freezer water pools at bottom of refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 09, 2009 | Frigidaire FRS26R4A Side by Side...
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
Fridge on fritz
Did you check the motor and/or damper mechanism that directs cold freezer air into the refrigerator portion. If that is messed up the freezer is ok but fridge is ng. Also look at door seals for proper sealing.
May 05, 2017 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
