Question about Smart Computers & Internet
Smart pad. Message on pump not working - Smart Computers & Internet
Can't get my iPad to work on my TCL smart TV
Possibly the TV is not as SMART as many of the newest one are .
Aug 20, 2017 | Smart Computers & Internet
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
Feb 26, 2015 | GE JVM1790 Convection / Microwave Oven
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
Sep 17, 2014 | ASUS MeMo Pad Smart 10
Smart-pad Elan doesn't work
the sensitivity of the mouse may need to be set.
http://www.thetechrepo.com/main-articles/458-how-to-change-mouse-sensitivity-in-windows-7
Aug 30, 2012 | Samsung Computers & Internet
My computer's smart pad is not working . how i can solve it?
You need to re-install the touchpad driver for your computer or try updating it from the device manager.
Aug 18, 2012 | Acer Computers & Internet
I replaced my front brake router and brake pads today. when i bleed the front left brake, a line which im assuming is a brake line near the rear left tire burst and is leaking brake fluid. when u tried...
First, there is NO Pumping of the brake pedal
involved in bleeding brakes
I think your smart enough to know you
need to replace both rear brake hoses,
before you proceed with the bleeding
Mar 22, 2011 | 1997 Chevrolet Cavalier
Why is my smart pad not working
I had issue with my Elan touchpad and my solution after a bunch of head ache was to shut down computer, unplug, and pull the battery out. After doing so I touched the touchpad while computer is off and the power button. Then put battery back in and started up and it was solved... Magic! It worked for my problem (Touchpad was not even showing up in device manager computer didn't think it had one, it wouldn't even work when I booted into Linux) There must of been some really weird charge on the capacitor so this allowed it to discharge. Think of it as hitting the reset button.
And of course make sure your touchpad is enabled in the bios or with the touchpad on/off button either on your keyboard F-Keys or a button next to the touchpad (that the touchpad off button is not set). Also check touchpad settings in your mouse settings section to.
Feb 16, 2011 | Acer Aspire One PC Notebook
Got an 05 smart forfour..having problems with the rear brake pads
both ,push in and turn at the same time ,difficult single handed but with a G clamp?? and snap on water pump pliers to turn it with its a fiddly job but not too difficult ,have you found your chassis number yet??? took me ages to find ---in the boot on the cross member under the floor
Sep 01, 2009 | 2008 Smart fortwo
Elantech smart-pad problem
The elantech settings have a box you can check to disable the pad while typing. Uncheck the box if it is checked.
Jul 17, 2009 | ASUS Eee PC 1000H Laptop
Key pad stop working
HI. this will happen over time if the microwave is used heavily and if it is over three years old. this key pad is attached to a smart board that you will need to replace. replacing the smart board will fix this issue.
Jun 06, 2009 | GE Microwave Ovens
Computers & Internet Logo
Top Smart Computers & Internet Experts
Computer Links
NOEL
NOEL
Pcm2048
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
