How do i open the lift gate on my 2011 traverse
Pushing the remote twice wont open it. where else in the traverse is there a release button
  • 405 Answers
SOURCE: 2006 chevy tahoe liftgate won't open when keyless remote unlocks
check fuse first always, then check connections fron rear gate to body.
Posted on Dec 15, 2008
SOURCE: the lift gate will not open with the release
I'm hoping you found an answer to this already, but if not, here it is. Try looking at fuse # 16 in the fuse panel under the driver side dash. It should be a blue 15 Amp fuse & it controls the cigarette lighter & lift gate, amongst other things. My guess is that you will find it has popped & needs to be replaced. It's an easy job to do if you have a fuse holder or a pair of needle nose pliers. Out with the old, in with the new. IMHO, this is a poor deign by Lincoln in the fact that the change holder is right next to the cigarette lighter & if you happen to drop a penny or dime into the lighter/outlet, it pops the fuse. This can be a common problem if you don't keep the lighter in there, & use the outlet for cell phone charger, ipod, etc. This has happened to me a couple times, so I bought a small box of fuses & keep them in the glove compartment now, just in case it should happen while I'm out & about somewhere. Hope this helps!...//TJ
Posted on Jul 27, 2009
SOURCE: rear tail gate will not open
how to i open a stuck lift garte on a ford winstar 2000 lock broken too
Posted on Aug 13, 2009
Check for broken wires running from the body to the trunk lid through the rubber boot.When the trunk is closing you can see the kink in the rubber boot.There are 11 wires to supply 1 solenoid so I think Chrysler knew there was problem.
Posted on Sep 04, 2009
  • 4399 Answers
SOURCE: My 2009 Toyota Highlander lift
Thanks for choosing FixYa and welcome to the site. You need to make sure that your fuse is not blown. Check your fuse box diagram for the location. If the fuse is fine, you may have a bad switch. There could be a loose wire or a bad connection to the switch.
Posted on Apr 20, 2011
How do you open the lift gate wont work? I have a 2007 Acadia and there is no silver lever visible through the access hole. is there a way to mechanic a way to jumper it?
Has to have it .
Liftgate Trim Panel Plug
From inside the vehicle lower the second and third, if applicable, row seats.
Use a small flat-bladed tool to remove the access plug from the liftgate lower interior trim panel.
Push on a silver lever located on the right just through the access hole to unlock the liftgate.
Open the liftgate from the outside of the vehicle using the exterior handle.
Outlook Traverse Acadia Enclave Lift Gate Won Open
Aug 24, 2017 | Cars & Trucks
How to change rear brake light bulb on a 2011 chevy traverse
Open lift gate. Locate two round caps on break light fixture and pry them open. Remove hex screws then light fixture. Twist light socket to separate from fixture. Pull out bulb from light socket. Replace bulb ( i used Sylvania 7443 )
on Jan 26, 2015 | Vehicle Parts & Accessories
Rear lift gate on 2011 Yukon only works with key fob. Friend mistakenly pushed down manually instead of pushing close button on rear lift gate . How can we fix it?
When the gate was used manually the inside button was deactivated. Look in owners manual or contact dealer to see how to activate switch.
Jun 09, 2017 | Cars & Trucks
Back tailgate lock won't open
Central lock problem, rear door and trunk don´t open - > ... > BMW SAV Forums > X5 (E53) Forum
Aug 23, 2014 - 10 posts - ‎4 authors
I have a problem on my X5, the remote key can only open the front ... I´m in a distante country without any BMW representative, but I can ... Remote keys can only lock andunlock the front doors, the rear door locks does not respond. .... the front doors openit won't unlock or lock the rear doors and rear trunk. Door Won't Lock With Key
Sep 26, 2013
Door Lock (passenger side) won't unlock with remote
Jan 10, 2011
Upper Tailgate wont open from the outside
Sep 2, 2009
More results from
X5 Tailgate Diagnosis E53 - YouTube
? 3:12
Nov 7, 2011 - Uploaded by AskTheCarExperts
Lower tailgate diagnosis including relay location and fuse location. ... BMW 3 Series E90 Car Key Memory and ...
BMW Electric Boot Release Fix - YouTube
? 10:02
Jan 23, 2011 - Uploaded by Cpt MishMash VonRandom
Thanks**This is a quick walk through to repair the boot or trunk release button on y. ... or other BMW of the ...
BMW X5 xDrive 30i automatic tailgate does not w
Dec 14, 2015 | BMW X5 Series Cars & Trucks
Gate light on dash will not go off also dome light stays on rear lift door is not jarred
Replace the gate latch. Open the gate, remove the top panel first, it pops off. Remove the bottom, 2 to 4 screws to remove, then it pops off. This gives you access to remove the latch.
Feb 13, 2015 | 2011 Jeep Liberty
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open?
Adjust Hydraulic Lifters?
How to open rear lift gate?
--------- Power Liftgate Shuts Down
------------ Power Lift Gate Will Not Remain Open
----------- Power Lift-gate will not Operate
------------- Liftgate will Not Stay Up Open?
---------------- Rear Door will not open
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside?
These details will help.
Nov 25, 2012 | 2007 Lincoln MKX AWD
Liftgate Release Not Working on a 2000 GMC Jimmy
plug on inside panel of lift gate remove plug and use screwdriver to push on release use light in plug hole
Sep 08, 2017 | 2000 GMC Jimmy
It seems that I have a short in my wires. My tail lights wont stay on. My problem is the lift gate is stuck and I cannot access the lights. When u use the remote to open the doors it makes a funny sound....
You should be able to remove the trimpanel on the lift-gate. then at the location of the striker in the middle-bottom of lift-gate you should be able to access a rod. Grab the rod with pliers, if pliers won,t fit the rod connects to a metal lever attached to the striker assembly, pry the lever away from the striker and this should release you gate....Good Luck!!!
Oct 15, 2009 | 1999 Jeep Grand Cherokee
Lift gate wont open
OK, this minor collision may have shifted the actual clip and latch assembly. You may have to totally disassemble the latch assembly to release this lift gate.
Any kind of major or minor shifting of the lift gate lock latch assembly can cause misalignment that will jam this delicate precise locking mechanism.
Apr 23, 2009 | Jeep Grand Cherokee Cars & Trucks
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
