Question about Refrigerators
I NEED TO REMOVE THE ROLLERS FROM MY BROKEN KENMORE REFRIGERATOR IN ORDER TO GET IT OUT A DOOR.HOW DO I REMOVE THE ROLLLERS SO IT WILL FIT THROUGH THE DOOR. THANKS
  • 631 Answers
Here is site that might have drawings on your fridge so you might have a better idea how to get them off.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
Kenmore Elite 106.54609300 What are the exterior dimensions? H,W,D I need to replace with a similar sized refrigerator in an enclosed spot. Can't find this info anywhere.
This is not credible request: Manuals are available from SEARS...
Use your measuring tape... and then go to the MANUAL and add the required clearances
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10654609300/0582/0165000?modelNumber=10654609300&diagramPageId=&documentId=26037129
STRAIGHT FROM THE OWNERS PDF
Door ...
shipping dimensions... seriously!
Part Information
This manufacturer-approved door assembly (part number L2255526LJ) is for refrigerators, including Kenmore refrigerator model 10654602300.
Unplug the refrigerator to disconnect electrical power before installing the new door assembly.
Follow the instructions in your owner's manual or installation guide to remove the existing door and install the new door assembly L2255526LJ
This Refrigerator Door Assembly part #L2255526LJ is guaranteed to fit your KENMORE REFRIGERATOR #10654609300
Door shipping Specifications
  • Category: Refrigerators and Freezers
  • Shipping Length: 77 in
  • Shipping Width: 28 in
  • Shipping Height: 13 in
  • Shipping Weight: 45 lbs
for questions or assistance, call 1-800-733-1381
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
(Se Habla Espa?ol)
Jan 03, 2016 | Kenmore Refrigerators
GE side by side refrigerator freezer door water tube broken
You need to contact a seller of GE parts with the model number of your fridge and order a replacement tube, these can be a pain to fit but not too hard.
Mar 10, 2012 | Refrigerators
Main door doesn't close easily
You may well need to purchase those bottom end parts to correct your problem. But first.....
Spray the door gasket on the hinge side with a food compatible
silicon spray. (makes it slippery).
Remove the heavy items from the door, and loosen the screws on the top hinge and try to adjust the door for a better fit.
Nov 03, 2009 | Kenmore Refrigerators
Freezer door won't open all the way
Sorry to see your post so late. I believe your drawer slide guides or the rollers that help balance the drawer are broken and in need of repair. I will give you a link and hope maybe I can be helpful. Thank You,Sea Breeze
Oct 09, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Replace Refrigerator Handle
should have screw covers to remove. then remove screws. cover are at top and bottom of handle. push up at top one and down at bottom.
Jun 21, 2009 | Kenmore Refrigerators
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller...
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Nov 18, 2008 | HP LaserJet 4100 Printer
Dryer
That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
  • UNPLUG DRYER
  • If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
  • with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
  • tilt lid up
  • remove 1screw each side 1/3 way down front
  • disconnect door switch wires
  • remove front panel and door
  • pull tensioner to end of its travel against tensioner spring, and unhook belt
    (Note:: position of belt around tensinoer and motor pulleys for reinstall)
  • pull drum out forwards
  • motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
3d57115.jpg bad roller
7133e59.jpg rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
  • pull old felt off
  • scrape off old adhesive
  • spread gllue on drum edge
  • secure felt on drum with visegrip
  • pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
  • allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
Oct 09, 2008 | Frigidaire FSE748GF Dryer
Kenmore Series 80 Dryer. Heats doesn't spin clothing. Imagine its a belt or spin motor. Need a schematic
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Aug 25, 2008 | Dryers
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
