Question about The Office Equipment & Supplies
The color on our Hanspree 28" 1080 HD TV is all wrong. How can we reset the color?
The color was fine until we put something under it to lift it for better viewing. Other than that, nothing changed.
  • 5 Answers
SOURCE: Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
Posted on Jun 29, 2007
RandyXi
  • 4 Answers
SOURCE: Adjusting visuals on the TV does nothing
This problem may have been coming from the Flyback Transfromer or the Tippler, you have to be a technician to adjust that! if you are, well first thing is to put the TV ON and sent up all the level to max for the brightness & Contrast, then after try to adjust the Flyback screen voltage for hi bright, if it work there, try back now to see if you are getting any control of the menu of brightness & contrast to work! please be careful, there about 28K volts to 35K volts, this can kill anyone... IF YOU ARE NOT A TECHNICIAN PLEASE DO NOT OPEN THIS TV.... RandyXi CriticaL PaniX
Posted on Jul 11, 2007
SOURCE: Hanspree TV chgs channel w/ cable remote but cant turn on/off
Thanks but I no longer require assistance. I tried to remove my post but it does not seem possible. I no longer need assistance because I sent the TV back. There is no solution as there is no universal remote code --- ridiculous for a brand new TV set that most people are probably going to want to use with cable!
Posted on Jan 14, 2009
  • 8457 Answers
SOURCE: picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Posted on Aug 19, 2009
  • 8457 Answers
SOURCE: 43'' HD projection philips tv color change
Check on ur auto covergence.Might have magnatics interference,the tv tech.use a dequasing coil to solve this prob.when it very bad,colors mast together.
Posted on Sep 12, 2009
My picture display is narrow and does not cover the screen.
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
Jul 30, 2014 | Seiki Televison & Video
I have a 47 inch Philips HD TV. I switched to FioS and for some reason, some channels come in very choppy or pixelated. It is not consistent but by analog TNT is fine but my HD TNT is pixelated. But my...
Long story short, it is not your fault. Your provider will blame you, TNT, will blame your provider, and both are wrong.
The most likely cause is HD TNT is not a "real" HD channel. It is probably an SD recording TNT is upscaling from SD to HD. This can occasional create a dirty HD signal being broadcasted. Some TVs have trouble decoding this signal and end up with pixelated images because the image has been pre-stretched to fix the format.
Temporary solution would be to change the resolution of you TV for just the TNT channel. Some TV will let you select a preferred mode for a channel. If you can do this, set it to 720p instead of 1080p or try 1080i for TNT to see if this improves the image.
Also make sure that only one tuner is altering the images you are receiving if you have a FIOS box. If it is processing the image image in any way (color correct, resolution, etc.) turn those features off and let the TV do it.
Apr 27, 2011 | Televison & Video
How to reset the picture settings
Go to the MENU and it should be under PICTURE select RESET.
Jun 08, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Color is pale
Reset colors,back to factory setting.Colors will be alot darker in ,can turn down colors after reset.
Jan 10, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Colors on my projection tv are out of aliangment
Yes sometimes moving can upset the converegence, I don't think you have a "perfect focus" button to realign pix..I believe you'll have go into the TV's menu and find the convergence menu (i think it's found under video settings) keep arrowing down until you find the option that reads something to the effect "reset to factory settings" and select it. That will realign the circuits... if you have multiple connections in use like an HD cable box, DVD etc.. you may need to do this reset more than once. In other words go to an hd input do reset, go to SD (standard definition) input and do the reset.
Rustym62
Apr 30, 2009 | Televison & Video
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Nov 29, 2007 | JVC HD-52Z575 52" Rear Projection...
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
22 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
