Question about Coleman Electrical Supplies
Why won't my coleman powermate 6250 s tart - Coleman Electrical Supplies
SOURCE: coleman powermate 6250 mod# PM0525303
I had the same problem on my Powermate 525500 (5500 watt) and finally manage to get in contact w/Powermate (PRAMAC) tech support. He told me that if the gen is setup for a while, the exciter loses it's magnatism. To reenergize ( jumpstart) as he called it, follow the prcedure below. Probably not for amatures.
1. start up the generator.
2. Pull off the brush cover on the end of the gen.
3. Get a 6-12 volt battery and setup w/color coated cables.
4. place the negative lead on the left side brush terminal and tap the right side brush terminal w/ the positive lead.
5. Wala....you sould have power.
One would think that this important info would be on the manual or a blog somewhere.
Good luck and have a wonderful day.
The Texajun
Posted on Sep 20, 2008
CarlGehrke
  • 169 Answers
SOURCE: powermate 6250 no spark
Hi Mark,
The engines used on the Powermates have a low oil shutdown system that can be troublesome. Try this:
1 - Make sure there is enough oil in the crankcase. The oli level needs to be all the way up to the bottom of the threads in the oil fill hole.
2 - Still no spark? Replace the spark plug with a new one (properly gapped), then spray something like brake cleaner into the carb. Pull the rope and see if you hear any detonations from the engine. If the engine tries to start but won't you need to look at the fuel system, then the ignition.
3 - If you proved there isn't any spark happening, look under the plastic cover where the kill switch is located. You'll find a small metal box with wires coming out of it. Find the wire that goes from the box to the kill switch and disconnect it at the switch. Mark things as needed so that you'll remember where to put them back. Give the rope a gentle pull and see if we have a working ignition, if it does have spark there is something wrong in the low oil shutdown mechanism.
4 - If you've convinced yourself that the low oil shutdown is misbehaving try changing this oil and flushing out the crankcase. Look for any evidence of debris that would have made the oil level float bind. As a final test reconnect the wire we took off the switch and disconnect the one that goes from the module to the oil sensor on the side of the engine, if you don't get a spark with the sonsor disconnected you probably have a bad module.
5 - If we didn't get ignition with the low oil shutdown disconnected from the kill switch, reconnect the wire we took off and then disconnect the (usually black) wire that leads down inside the engine. This is the kill wire for the ignition module. If you get the engine to start with this wore disconnected you may have a shorted kill switch, test it with an ohm meter.
6 - if there still isn't a spark with the kill wire disconnected you may have a bad ignition module. You have to take off the carb, then the blower housing to get to it. Check that the kill wire isn't shorted to the block anywhere, and that the module has the proper gap and orientation before replacing it, The modules say "cyl side" on the side that should face into the engine. A regular business card or a playing card ought to just fit between the magnet on the flywheel and the module, too loose would cause a loss of ignition. You get extra points if you use a feeler guage to set the gap to 0.010 inches.
7 - Ignition modules are available from a bunch of different places, your local Briggs supplier will want to know the model, type, and code numbers located on the side of the valve cover in order to be sure which parts you need,
Rate me if you liked the answer,
Carl
Posted on Dec 01, 2008
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: owners manual
Try this link. The model number will be on your endbell.
http://www.powermate.com/productmanuals.php?cat_id=3
Posted on Oct 13, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Posted on Nov 23, 2009
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
49 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
