Question about Epson Office Equipment & Supplies
I have Epson WF-3620 and I am getting error code of 0x97. I need to clear it
  • 2848 Answers
SOURCE: Epson WF-2650, bran new, already shows error 0xF3. How to clear?
Error Code 0xF3 means a hardware failure. Call Epson....
Posted on Jan 31, 2015
  • 48473 Answers
SOURCE: Workforce WF 3620 error codes
search for this on Google
Posted on Nov 22, 2015
AJIN G
  • 6694 Answers
SOURCE: how can i fix the error problem on my epson wf-3540 code 0xfa
for more details check the link bellow
http://electro-medical.blogspot.com/
Posted on Dec 26, 2015
niteshs410
  • 3 Answers
SOURCE: how to fix epson wf-3540 error code 0xFA all it tells me is to unplug then plug it in and still dose not work
Hi Robert,
Please reinstall a fresh driver after complete removal from printer and faxes and reinstall it hope this will fix your issue.
Thanks
Nitesh
tinman59
  • 15 Answers
SOURCE: Epson WF 3640
locate the top lid of the ink cartridge holder, there is a little arrow on it. Push down there until it clicks shut.
Posted on Sep 15, 2016
What is an Ox97 or 0x97 error code on an Epson WF-3640 printer?
Error Code 0x97 in Epson WF- 4630 means there is decrement in efficiency of printer. The printer may be not printing the pages as it used to print earlier. You don't need to worry anymore. You can follow either of the Solution to resolve the Error.
Solution 1:
Step 1: Download "0x97 Fix Patch:
Step 2: Click "Scan" button.
Step 3: Click :Fix" button to repair the Printer.
Solution 2:Step 1: Restart the computer. Login as an administrator user.
Step 2: Click "Start" button> "All Programs"> "Accessories"> "Tools"> "System restore".
Step 3 : Now click "Restore my machine to an earlier date"> "Next".
Step 4: Select most recent system restore date within the "tap a restoration date" Listing and click "Next".
Step 5: Click "Next" on the verification window.
Step 6: Restart your PC is required after the completion of restoration process.
Now, try to work with your printer again.
Call Epson Printer Support Team 1-800-213-8289 if the Error is not resolved or you are having any other kind of issues.
Visit: Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Jul 06, 2017 | Epson Office Equipment & Supplies
How do I fix error code 0x97 on Epson printer
0x97 is a scanner circuit board error. You can reset your printer by unplugging it from the wall for a few minutes, and then trying again. Unplug is not the same as "turn off". Other than that, service center is your only answer.
Jul 05, 2016 | Epson WorkForce WF-7620 Wireless Color...
I cannot find the online user manual for the WF-3620!
You can find easily by google it, Just type the model number of printer with user manual or user guide
you can use this key work " epson wf-3530 user's guide "
https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?UseCookie=yes&oid=232591&infoType=Doc
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
Feb 01, 2016 | Epson WorkForce WF-3620 Wireless Color...
What is error 0x97 and how do you fix and prevent from happening again
I think that is a printed circuit board (PCB) problem and is not user repairable. You might try unplugging the printer, wait about 10 - 15 minutes, hold down the power on button and plug the printer back, continuing to hold down the power on button for at least 60 seconds. If it doesn't clear the error code, it's a circuit board problem. If the printer is out of warrantee, it's cheaper to buy a new printer.
Sep 24, 2015 | Epson WorkForce WF-3640 Wireless Color...
What is error 0X97?
Aug 29, 2015 | Epson WorkForce WF-3620 WiFi Direct...
How to resolve error 0x97 on Epson WF-3640?
First, here's a copy of the manual:
https://files.support.epson.com/docid/cpd4/cpd40083.pdf
Second, attempt the following which I copied this answer from another post concerning the same error code:
"The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times." (Post by Anjazmoro Wicaksono)
If that does not work, are you able to open the printer and look for anything that may be blocking proper function?
Jul 03, 2015 | Epson WorkForce WF-3640 Wireless Color...
On an Epson WF-4630, what does error code 0x97 mean and how do I correct it?
I am on my second printer with the error. Epson explained it is a motherboard failure. The error is not caused by a PC or the software on it. Instead, this is a printer hardware failure.
After exchanging the printer, the replacement printer has now dies from the same error. The problem starts as blurry printing and progresses to the full hardware failure. Once the Hardware fails and you get the error code, there is nothing an end user can do. The motherboard needs to be replaced.
My printers were working fine up until I swapped out the factory cartridges that shipped with the printer. In both of my cases, there were no issues or symptoms until I started using the Epson XL cartridges. As soon as I installed those, the symptoms started to show. Within a couple of months after swapping in the XL cartridges, the motherboard dies.
Options:
1) Call Epson and complain, make them log the details even if it is out of warranty. This helps establish the pattern and knowledge of the issue.
2) Swap printer if under warranty. They may want a credit card to charge in case they do not receive the bad printer back. Just resend it in the box the replacement came in. Epson supplies shipping labels and covers the shipping costs.
Mar 27, 2015 | Epson WorkForce WF-4630 Wireless Color...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
