Question about Home
The start button on a mira events thermostatic shower cannot be depressed so the shower wont start
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
SOURCE: Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Posted on Mar 16, 2010
SOURCE: mira thermostatic shower water dripping from
Switch off the power supply to the shower at the consumer unit, it will probably have its own individual circuit breaker as it is such a heavy user of power. Try now to switch the shower, it should be dead and that is good. Remove the control knobs and remove the front of the shower unit. Check the electrics with an electrical screw driver to make sure that there is nothing that will cause electrocution. Trace the source of the leak, the most likely place is the compression joint to the mains water pipe. Tighten the compression nut until the dripping stops. Dry everything off with a paper towel and check there is no sign of further leaking. Reassemble the front with the knobs and switch the power back on.
Posted on May 28, 2010
  • 42 Answers
SOURCE: Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Posted on Dec 18, 2012
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
How do I find the serial number on my Mira Excel thermostatic shower
Should be a sticker on the box it came in.
Mar 02, 2015 | Home
Need to find a serial number
Should be a sticker on the box they came in . If not there may be a small screw on the underside of the shower unit to undo
Mar 02, 2015 | Home
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
My Mira Event Mk1 shower keeps tripping when i switch it on
It's wired with wrong cable if fitting a shower up tp 8.5 6 mm twin and earth needed if 9.5 or 10 fitted 10 mm twin and earth needed and fuse at mains box must be 45 amp
Sep 23, 2012 | Home
Mira shower will only run cold as soon as dail is turned up a little lights go off and will not re start for a good while .advanced electric shower
It is posebel that the thermostat has broken, take off the cover plate and faucet ant take out the thermostat and ask a elektrician at a shop to test it for u or geta new 1, hope it helps .that is 1 of the most commen mestakes when that problem ocers
Jun 11, 2010 | Home
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
