Question about Cameras
Battery was drain and now I put charger on and all the lights starts flashing
    Top Expert:
  • Cameras Master
  • 26,256 Answers
Probably the alarm think it has been tampered with. Switch the alarm off.
Posted on Aug 10, 2017
5 Suggested Answers
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
Posted on Feb 18, 2009
57 varieties
  • 1653 Answers
SOURCE: put battery in charger and red light just flashes.
This is usually because the battery is faulty and needs to be replaced. Just to be sure, turn off the charger and then back on again. Put the battery back on charge to see if the error is repeated. If so you will need to obtain a replacement battery. Unfortunately, this does happen with a fair number of rechargeable NiMh and Lion batteries and many are no where near there expected lifecycle of 1000 recahrges.
Posted on Oct 13, 2009
  • 3600 Answers
SOURCE: 2007 hhr. Battery was drained. Mother left lights
your alarm system has been tripped when the battery went dead, to get the information on how to reset the alarm is to call the car manufacture to get the procedure, and should not cost you anything.
Posted on Jun 23, 2010
SOURCE: flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Posted on Mar 31, 2011
Just did tune on 1994 chevy impala and now the pass key fault light flashs and car want start
Relearn procedure--- Turn the key on for ten minutes, turn it off for five seconds. do this three times and after the third time it should start. Just a note... Put a battery charger on it as this procedure will drain the battery.
May 22, 2011 | 1994 Chevrolet Impala
Phone doesent turn on flashing red light when you push the power button. please help.
Try this , it helped me. 1. plugin the charger (or data cable) for about 15 minutes and keep the red light blinking. 2. while the charger (or cable) is hooked to the phone, remove the battery and memory card for 10 to 12 seconds. 3. keep the memory card out and put the battery back in and whalah, it startes up. (really hope this helps)
Nov 14, 2010 | Sony Ericsson XPERIA X10 Cell Phone
2007 hhr. Battery was drained. Mother left lights on overnight. Tried jump starting no good. Tried charging with new charger nothing. Did notice that once you put the key in the car the alarm lock light...
Jun 23, 2010 | 2009 Chevrolet HHR
Casio Exelim EX-Z77 battery will not charge, charger light flashes on and off.
Your battery maybe drained, you can try to leave it in charger for hours( it will take long for a drained batt to start charging) blinking led may indicate that charger is trying to supply current to batt, anyways I strongly suggest you to buy a new one
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
My camera wont charge correctly
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 29, 2009 | Casio Exilim EX-S880 Digital Camera
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Truck won't start, new battery, lights keep flashing
Sometimes the new battery is not 100% charged. Put it on a charger or jump start the car, the alternator should then charge up the battery.
Oct 09, 2008 | 1993 Toyota Pickup
Flashing lights
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
