Question about Canon Office Equipment & Supplies
Pls how do we fix inner finisher on canon IR 2545i
I need help with this error ImageRUNNER 2545i error code e000000
Hi. you need to enter in service mode
in the control panel do the next key secuence:
press adittional function
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Apr 07, 2017 | Canon IR 2545i Copier machines
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
What it a finisher for canon ir 2520
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
Ir4570 message: finisher cannot be used help me pls.
Dear colleagues,
I have Canon IR 3045, is giving the following message "finisher cannot be used" is there any solution to reset the message.
Many thanks for any assistance.
Sep 16, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
41 people viewed this question
old marine
old marine
