Question about Minn Kota Boating
We have a Minn Kota riptide 55. Serial WWAI12730357. Used once when new and has been sitting since. We need a manual.How do we go about getting same.
    Top Expert:
  • Minn Kota Master
  • 42,991 Answers
Try googling it Google
Posted on Aug 10, 2017
4 Suggested Answers
snowghost1
  • 784 Answers
SOURCE: I have the Minn Kota
if it is not steering with the remote - then the problem could be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
the best way to trouble shoot the unit would be to open the case and use volt meter to trace the voltage flow. also make sure you are getting power to and thru the remote as I have seen the control buttons go bad.
if you are still having troubles and have more questions - please feel free to write me back here and I will do my best to walk you through the steps needed to fix or trouble shoot more.
have a great night,
c...
Posted on Feb 21, 2011
  • 4336 Answers
SOURCE: Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Posted on Mar 14, 2011
  • 1156 Answers
SOURCE: I need a schematic (not
Use the link and get necessary information on schematic diagram you want..
Use the search engine to search for you schematic
http://www.northlandmarine.com/MinnkotaTillerSteering.html#anchor_ENDURA_DIAGRAMS
Posted on Sep 22, 2011
Minn Kota rip tide st 55 very noisy
is the prop shaft bent you may have busted a magnet in the motor dragging now
Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
Jun 29, 2011 | Minn Kota Riptide 40 Transom Mount...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
How does the pin that holds the yoke come out. I have tried knocking it out with no luck. I also can't seem to find any retainer holding the pin in.
call the 800 number for minn kota on the motor. they will be able to tell you the best way to remove it on that particular motor. they have a very good tech support system at that company.
May 29, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
My minn kota riptide 55 stopped working when i turn the handle. i believe its a connection issue. i dismantled the housing around the handle and a little metal washer fell out broke in half and the pieces...
Hi!
To start with, here's a schematic:
RT55 Hand Control
Sounds like key# 87 broke....seen it before.
To replace it, remove top cover, then remove the handle portion by removing the 5 screws underneath. There are a few peices in there, so keep close watch. Also be careful of the fine ribbon wire attaching the handle to the control board...it's pretty fragile.
Best of luck!
Mike
Sep 27, 2009 | Minn Kota Riptide St Saltwater 55 Bow...
Minn Kota 55 directional problem? (night fisher)
Hi!
Here is a schematic:
Max 55
There is no LIGHTED directional indicator, but there should be an indicator nonetheless on top.
Best of luck!
Mike
Jul 07, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Boating Logo
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
