Question about GPS
Does zio p3 ph have wifi or gps capability - GPS
How to put password in wifi router?
Open Browser ( Firefox, internet explorer, ext)
type your computers IP address where you would normally type the web address, press enter.
your router settings should now come up but you need to enter a username and password before you can make changes.
try using user name (admin) and password (admin).
now look for the security tab and edit as needed.
Nov 23, 2012 | Zio Televison & Video
Need manual for the x11-15302
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=654e30a291cfc737252332732815f4a0&modelid=23204612&q=Nextar+P3
Oct 18, 2012 | Nextar P3 GPS Navigation System
I HAVE A GARMIN GPS WITHOUR ANY CONNECTION WIRE TO COMPUTER, CAN I DO ANY UPDATE
Unfortunately you need the wire unless it has wifi capabilities. Garmin says you must get the wire from them but I have heard of others doing this with a generic/aftermarket cable for just a fraction of the cost.
Jan 25, 2011 | Garmin nuvi 205 GPS Receiver
Will not work on windows 7
Go to Zio's website to see if they have win 7 drivers. If not, then you are out of luck.
Jun 12, 2010 | Zio Corporation Dazzle Digital Video...
The screen won't light up on my nextar #P3 GPS
press the reset button on the back. i had the same prob.
Jun 09, 2009 | Nextar P3 GPS Navigation System
Nextar X-11-15302 or P3
A generic 12 volt adapter should work. I replaced mine recently. They usually come with multiple sizes of round ends and can adjust the output voltage. The side of the device will tell you the polarity and the voltage required. If it says something like 5 V but the adapter only has 4.5 V or 6 V, select the closer choice. If they're about equal, select the lower one. It is better to have an under volt than an over volt.
Feb 16, 2009 | Nextar P3 GPS Navigation System
Need nextar p3 map program for SD card
I have same problem, am going to buy anotherone at Kmart copy the files from the new card and put on my old one. Will let you know if it works. Then take the new one back of course.
Dec 30, 2008 | Nextar P3 GPS Navigation System
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
