Question about Refrigerators
Ice cubes are sticking together and won't dispense.
  • 481 Answers
SOURCE: Ice dispenser in door will not dispense ice
this could be the:
door switch (usually 2 switches, 1 for the light and 1 for the dispenser) auger motor itself the dispenser switch or the plug near the hinge that connects the door the the refrigerator has a bad connection. this connection is hidden under a plastic hinge cap usually.
Posted on Jun 28, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
Whirlpool model # ed5vhexvq1 side by side maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice cubes stick together
have same problem with industrial ice maker machine at my work because the setting is too cold to let the ice cubes separate.
Apr 15, 2014 | Refrigerators
Adjust cube size
If your ice container is also on the door then the issue is in your ice chute with the dispenser door. If your ice bucket is not on the door the issue is your defrost timer sticking.
Mar 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice sticks together
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
Apr 05, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Ice cubes melting and then sticking together
If you have dispenser to get ice or water, there is a cover to it that opens and closes as you ask for ice. If that mechanism is not working it stays open all the time and causes your ice to melt because cold air scapes. You should be able to replace that yourself. Sears sells that part. It is not very expensive. There is a cover over the dispenser pannel. It should right behind it
If you Agur that suppose to turn the ice to dispense, that could burn up too because the agur can not turn all chunk of ice
Aug 01, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice cubes sticking together on ge modeltbx20tub
If the cubes appear to be shells, you have a restricted water supply to the refrigerator and will need to change the saddle valve where the 1/4" line connects to the house plumbing.
Dec 18, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
