Question about Xerox Office Equipment & Supplies
Xerox 5875 drum chip not working plz tell me solution
3 Suggested Answers
SOURCE: toner drum chip reset for xerox docucolor 250
dc250 crum reset solution done yes B Patel mumbai 09029222006
Posted on Sep 23, 2009
sanimd85
SOURCE: reseting xerox drum chip xerox 5834/vivace 340
canon pixma ip3680 absorber is full
Posted on Apr 07, 2013
How to set the face up print in xerox workcentre 5875 printer
I am assuming you are using the document feeder, either way, usually found through the options one the menu once you select the copy tab. Select all the options you want applied to this particular job and then copy. If you wish for them to be permanent please go to Xerox's website and download the applicable manual - usually the system administrator's manual.
Xerox support for this model is located:
http://www.support.xerox.com/support/workcentre-5865-5875-5890/documentation/enus.html
Best wishes,
Joe
Aug 25, 2016 | Xerox Office Equipment & Supplies
In Xerox work center 7345 error coad 0004361 plz give me clearance of this
That error is a drum motor failure. It can be either a seized drum or a motor. Remove drums and enter diagnostics and test the motor first. If that passes put back in one drum at a time and then run the test after each one to identify bad drum.
Jan 12, 2016 | Xerox Office Equipment & Supplies
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
Reseting xerox drum chip xerox 5834/vivace 340
you should change drum chip then fix your problem
Apr 01, 2009 | Xerox Office Equipment & Supplies
Toner drum chip reset for xerox docucolor 250
Jul 21, 2008 | Office Equipment & Supplies
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
