Question about Vtech Lands Phones
My vtech handsfree phone has no dial tone - Vtech Lands Phones
    Top Expert:
  • Vtech Master
  • 48,512 Answers
Then call your phone company and report outage. use someone's cell phone
Posted on Aug 10, 2017
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
SOURCE: vtech phone problem Model # LS6117-5 DECT 6.0
take out battery for a few seconds then put back in. My phone just did the same thing and it kixed it. Not sure why it happened though
Posted on Jan 20, 2009
SOURCE: I can't dial out from my handsets
Monotary suggested the following and it seems to be working for now.
"Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself."
Posted on Feb 11, 2009
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
Posted on May 13, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
When I dial out on my Vtech phone, it goes back to a dial tone or a busy signal
Are you sure that the phone is even trying to dial? Push 1 digit and make sure dial tone is going away. Could be bad dial pad.
Apr 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to change a vtech phone to tone
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual. The manual will explain how to switch your phone between pulse and tone dialing.
Nov 21, 2013 | Vtech Lands Phones
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
No dial tone
vtech are not very good u mite need another fone
Sep 09, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
How to change from pulse dialing to tone on vtech 5.8GHz
Here are the instructions for one vtech phone (may not be quite the same as yours but may work or give enough hints for you to figure it out):
Press PROG.•
Press ? or ? until the screen displays DIAL MODE: and the current setting.
Press SELECT. The current setting blinks.
Press ? or ? to select TONE or PULSE.
Press SELECT to save.
Mar 22, 2009 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
48 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
