Question about Kenmore Refrigerators
How do I remove the switch panel from Kenmore Coldspot Model 57262791
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck
Posted on Apr 30, 2008
  • 113 Answers
SOURCE: Kenmore Elite Coldspot side by side Model #
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
Posted on Jul 21, 2009
  • 1776 Answers
SOURCE: how to remove top panel of kenmore dryer model
Check the video at the following link and see if you find the information helpful in changing the door switch. Sure hope it does and best wishes.
Posted on Oct 01, 2009
  • 5911 Answers
SOURCE: Model #110.26901691 Kenmore washer. Need to
The end caps come off by placing your hand over the TOP of the console and lifting each one from the back and pulling forward. If you can't get them to come off by hand, try placing a screwdriver in the top groove in the back and give it a twist to pope the cap free. Once the caps are removed follow these steps:
1. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If you are replacing the lid switch, you will now have full access to remove it from the under the washer casing.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions about this repair, please post back and let me know. You can view some excellent exploded view diagrams of your washer at for assistance in locating parts if needed. I hope this helps you.
Posted on Dec 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: i have a kenmore coldspot
It is possible that the switch at the dispenser switch is defective but not as likely as the water control valve=> W10408179 found on the rear of your refrigerator. The coil may be burned out or weaking and not allowing water to flow when you press your cup to dispense. Have someone ohm both coils and the resistance should be close to the same. Applying 120 volts to the water dispenser side of the dual valve should cause water to flow. They just sometimes burn out and yes the dispenser components wearout too.Large View=> 10656356500_Dispenser_Parts To remove the Face of the dispenser follow the instructions in red at bottom of photo=> HERE Use care and mark and remember were the screws go when you replace the facade. If you have any other questions I will be here, Thanks, Sea Breeze
Posted on Jul 24, 2011
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
Jan 31, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
