Question about Kenwood Car Audio & Video
Kenwood DPX510 is open only rear speaker,front can't be open and the audio is very poor. How to change settings?
merle840
  • 113 Answers
SOURCE: kenwood kdc-1028
the remote is blue - the ignition wire12 volt is red - the battery line 12 volt is yellow
Posted on Mar 27, 2008
  • 69 Answers
SOURCE: audio system
#1. Remove 2 screws above speedometer. and then remove the 2 screws under the AC/heater control
#2. to get to the rear speakers you can either go through the trunk to remove the speakers or take the back seats out.
you dont usually have to remove the rear panel. the speakers slide right out from bottom.
Posted on Aug 13, 2008
  • 4 Answers
SOURCE: FRONT SPEAKERS HAVE NO AUDIO AND REAR SPEAKERS IMEDIATELY FADE
check all your wires in the front speakers and make sure there coverd
Posted on Dec 06, 2008
RickOz
  • 145 Answers
SOURCE: Rear Speaker Wont Play
This is most likely a driver issue. I would goto the creative site and use their automated updating tools.
Posted on Mar 26, 2009
SOURCE: Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Posted on Apr 17, 2009
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Hooking up kenwood cd player in a 2000 silverado but the wires aren't labeled coming out of the cd player. Pls help
If you use a wire harness adapter, you just have to match the colors from the Kenwood plug to the wires in the adapter. No guesswork.
Kenwood uses the CEA standard for car audio wiring:
Yellow: 12VDC constant power
Red: 12VDC key-switched power
Black: Ground
Orange/White: Illumination
Blue/White: Remote output for amp turn-on
Blue: Power antenna activation
White: Left front speaker (+)
Gray: Right front speaker (+)
Green: Left rear speaker (+)
Violet: Right rear speaker (+)
Each wire with a black stripe is a negative speaker output.
You can download owners' manuals from Kenwood's web site.
Jul 16, 2015 | Kenwood Car Audio & Video
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
Need to wirer kenwood kdc-hd545u radio to my 1999toyato avalo and the wirer harness has been cut off the toyato need wirer diagram to match wirer colorsto make it work!!
1999 Toyota Corolla Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Oct 14, 2012 | 1995 Toyota Corolla
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
Rear Speakers
Hello kaykayscott1,
Here's a link to the manual.
First make sure that the green green/black and purple purple/black pairs of wires are properly connected to operate the rear speakers.
You can check and adjust the "fader" and "rear volume" settings from the front panel. Go into settings by pressing the CONTROL knob. Then press CONTROL repeatedly until you get to the setting you want to check or adjust. When the display reads "R-VOLUME", turn the CONTROL knob from 0-35. Press CONTROL repeatedly again until the display reads "FADER" and turn the CONTROL knob from Rear 15 - Front 15 until you get the setting you want. Exit audio control by pressing any button.
Hope this helps.
Jul 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-X590 CD Player
what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
Aug 12, 2008 | Kenwood KDC-X590 CD Player
Speakers
It's a universal color code.
front right is gray
front left is white
rear right is purple
rear left is green
The black striped wire on each set is the negative.
Dec 08, 2007 | Kenwood KDC-2011S CD Player
NO audio from front speakers?
Have you tried turning the zone off completely? I had a similar problem, but once I released zone it stopped acting weird
Nov 27, 2007 | Kenwood KVT-719DVD 7 in. Car Monitor
u need to set the fade value to boost the front speakers more.i have it at 7 if i remember correctly.almost all the way up.about 4 or 5 steps before u cut off the rear ones completely.hope that helps.
Nov 26, 2007 | Kenwood KVT-719DVD 7 in. Car Monitor
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
