Question about Panasonic Office Equipment & Supplies
I HAVE A PANASONIC KX-FT72SA THERMAL FAX MACHINE. I HAVE NO POWER, BUT WHEN PLUGGED IN, I HEAR A PULSE TONE WHICH IS CONTINOUS. WHAT IS THE PROBLEM? I DID CHECK THE FUSE.
SOURCE: change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: Panasonic kx-fm386 problem
I NEED THE CD ROM OR DRIVER FOR THIS PRINTER PANAFAX UF-490 OR PANASONIC UF-490
Posted on Apr 12, 2009
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
FixinFax
  • 3085 Answers
SOURCE: Fax Machine Panasonic KX-Fl511 a fax was sent
Unplug the power cord for 10 mins.
Posted on Jul 02, 2009
SOURCE: I have a panasonic KX-TGA101s
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
Posted on Jan 15, 2011
Fax machine won't power up
Try pushing the power cord firmly into the back of the machine
Jun 22, 2009 | Panasonic KX-FM220 Plain Paper Thermal Fax
I have no dial tone. Cannot use the fax feature.
Check the condition of the phone cord, is it plugged in at both ends?
Do you have another cord you can try?
is it plugged into the LINE jack on the machine?
If you call it what do you get?
if you plug a phone into the wall jack does it work?
Unplug the machine from both the power and the phone jack, leave for a couple of minutes and plug them back in and turn the machine on, Any luck?
Try these, let us knowhow you made out.
ed
Apr 30, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Is it possible to change from pulse into tone on Panasonic phone KX A145? I can't find this function on the phone. Does anyone know if it exists at all? Is there any general rule that may apply to all...
On this side of the pond, a KX-145 is a drum for a KX-F3000 fax machine with phone ! If that happens to be yours, under the * key, there's a stencil that says TONE. If you are trying to convert all calls to tone, then try the panasonic web site and look at the nameplate on the machine for whatever it happens to be.
If the search engine screwed up, then look to use the # key or a tone/pulse switch on the side of the phone.
Carl
Apr 11, 2009 | Lands Phones
Panasonic KX F511 wont' send or receive
If you cannot send or recieve. First make sure you have a dial tone at the jacj in the wall if you cannot hear it on the handset of the fax plug a phone into it and make sure.
Second make sure you have the line from the wall plugged into the jack on th machine that says LINE. Most machines have three jacks Phone handset and LINE Make sure you are in the LINE jack.
Hope this helps
Feb 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Communication error # 43on panasonic kx-fhd331
problem with your machines ncu or mb unit.check with proper technician.
Mar 26, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
