Question about Grilling
I have a Brinkman Select 6 burner gas grill ,can not get the igniter to work . have changed the battery
    New Friend:
  • 3 Answers
Make sure the battery is installed correctly.
Posted on Aug 30, 2017
  • 2,065 Answers
SOURCE: Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Posted on Oct 31, 2008
SOURCE: gas grill loses pressure while side burner does not
I had the exact same problem with my Jenn-Aire and so I replaced the regulator for $20 and it now works fine.
Posted on Feb 28, 2009
  • 63 Answers
SOURCE: Igniter problem
right in front where the red botton pushs in to light! grab the ring around that and un screw it!
Posted on Apr 05, 2009
  • 81 Answers
SOURCE: Grill mysteriously not working, gas tank full, can't smell or hear gas come to burner
Go to Dome Depot. Lowes or whomever your large hardware store is and get and new regulator and connecting kit (it is probably the regulator), they are not expensive. If this does not do it, it may be the valve on the broiler, but not likely.
Posted on May 08, 2009
  • 14 Answers
SOURCE: new brinkman gas grill---side burner lights on
I have a few ideas that might help.
1). Before going to the expanse of new parts, your igniter AA battery MAY need replacing.
2). Your igniter wires might be loose. Remove the battery and check junction box found behind the Control Panel and connect any loose wires.
3). Check that the end of each of your main burner tubes are properly located over the gas valve fitting.
4). There MAY be an obstruction over the main tubes not allowing the gas lines to access it properly.
5). If obstructions in the hose or regulatory assembly is suspected, it would be best to contact Brinkmann directly at 800-527-0717
Posted on May 30, 2010
I have a Brinkman BBQ.The igniter works and lights the main burner but when I turn on the second burner it wont ignite.I can light it manually so it clearly it is getting gas. What do I need to do?
Check the igniter with the gas off to make sure the secondary igniter is lighting if it has one. Otherwise reposition the igniter closer to the source. If it isn't flashing, if not, it needs replaced
Nov 16, 2016 | Grilling
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Brinkman second burner not lighting
Sometimes by the igniter there's a small deflector that directs 1 jet over to the gas outlet holes on the second burner. You can always get a butane extendo lighter and do it manually (or a match on hemostats)
Jul 15, 2012 | Brinkmann Grilling
Looking for a brinkmann 810-3200G replacement burner
Unfortunately, your model grill has been discontinued by Brinkman. The burner you need, Part # 19810-3200-G is no longer available and there is no substitution.. Neither from Brinkman or other grill part sources. In fact, the only 2 parts available from Brinkman for you grill are an ignitor button & cooking grates.
I'm sorry, I wish I had better news for you. Thanks for choosing FixYa.
Jul 27, 2011 | Brinkmann Grill King Deluxe 810 3200-0
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
Just purchased new Brinkman 5 burner Pro series. Worked fine when I tested it but now the main burner is the only one that will ignite and it won't stay on. The side burner works great.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Jun 19, 2011 | Brinkmann ProSeries 810-6330-W Grill
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Igniter problem
Apr 04, 2009 | Brinkmann 810-2300-B Grill
Grilling Logo
280 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
