Question about Refrigerators
2 Suggested Answers
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: water leaking into the bottom of refrigerator
    Hello - There are a few reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, or a leak from the water supply line for the dispenser or ice maker (if you have a side-by-side refrigerator). Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. If these suggestions prove to be ineffective contact a professional to move forward accurately.
    Posted on Nov 29, 2012
    I have water coming out from bottom of my machine and dont know why
    seal failure most likely problem. or tub rusted thru
    Aug 10, 2017 | Washing Machines
    We have water coming from the freezer compartment..alot of water from where is goes into the icecube maker, and dont know why
    Water valve is not closing all the way and needs to be replaced. Water valve is located behind the refrigerator at the bottom.. It is blue in color so easy to spot.
    Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
    Aug 29, 2011 | Refrigerators
    I dont know if the water **** is bad or if there are busted hoses, but I see water squirting out of a little L shaped hose and water runs out at the bottom. If I buy a new water pump what hoses do I buy as...
    Water pumps usually have a weep hole on the bottom of the snout. This is put there so when the seals go bad you will know from the water leaking out. Try to look for that weep hole and see if coolant is coming from there before spending money on a pump. If the pump does not look as if it has been leaking then maybe its just the hose.
    Not knowing what Pontiac car (or Truck) you are working on and what hose specificly. When asking for the hose at the store just tell them where it goes to. Water pump bypass, water pump to intake, water pump to heater core, etc..
    Aug 25, 2011 | Pontiac Grand Prix Cars & Trucks
    Hi I have this maytag upright freezer model # is MQU1556AEW the problem is that at the bottom inside the freezer there is alot of ice i dont know where this water is coming from I clean but that ice every...
    We too have this 2005 model and have to remove ice at the bottom each a new freezer before we lose all contents.Looking at Amana...high ratings and few complaints
    Oct 22, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
    I have a Nextra HNF71683D washing nachine. When i
    E05 NTC temperature probe faulty or open circuit.
    Oct 16, 2009 | Hoover Washing Machines
    Water is coming out from bottom of machine
    I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part. If any help, I did take some photos of the session.
    Sep 27, 2008 | Saeco Incanto Classic Espresso Machine
    Fills with water slowly when not in use
    You have a faulty solenoid valve..
    At the back Where the water inlet pipe connects to the machine, the valve it connects too is faulty order a new one and replace it yourself... al you have to do is remove the top to get to it.. and its straight forward ......
    Hope this helps any questions dont hesitate to ask ....
    Jan 22, 2008 | Electrolux EW1200i Front Load Washer /...
    Refrigerators Logo
    24 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
