I have water coming out from bottom of my machine and dont no why
    Top Expert:
  • Washing Mach... Master
  • 49,270 Answers
Again, it could be worn seals or rusted thru drum
Posted on Aug 10, 2017
I have water coming out from bottom of my machine and dont know why
seal failure most likely problem. or tub rusted thru
Aug 10, 2017 | Washing Machines
Hi could you help my machine is spinning but the washing is still coming out dripping wet
check that you dont have too tight a bend or squash in the outflow tube the corrugated one leaving the washing machine, or also check you dont have anything blocking the tube as the water has to escape, also worth checking does your machine have an inspection panel with drain port on front bottom. if so opening the port will let all the water out so have mop handy, but you should be able to get access to the impeller which pushes the water up the exit tube and make sure nothing is blocking the impeller
Mar 17, 2015 | Washing Machines
How do I clean the filter at bottom of the machine. Do I have to add water to machine afterwards? If so, how much?
Just pull filter and clean, replace and u r done. The water that comes out is just what's left after each wash load.
Mar 04, 2015 | Washing Machines
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
No drain now cant get door to unlock and repair man cant be here for a week
Try to get water out first then the door may open with power on.there should be a little door or flap at the bottom front of machine to drain water manually,you may also find when you do this that rubbish will come out & machine will start working again & pump its own water out.The pump is probably just blocked & you need to clean it out..You would be surprised how many people dont even know that there is a little compartment down there at the bottom that they are supposed to clean out regularly.
May 28, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Water leaks from bottom
Sounds like your drain hose isn't connected properly to the machine. Look for the base of the hose and see if there's something you can do.
Nov 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Water is coming out from bottom of machine
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part. If any help, I did take some photos of the session.
Sep 27, 2008 | Saeco Incanto Classic Espresso Machine
Washing machine leaks from bottom
Open up behind after pluging off the wall. Check the hose that comes from under the tub, likely it is damaged or slipped out. Refit or change if damaged. You need a good pair of pliers; dont forget to insert the grip clips well.
Jan 01, 2008 | Washing Machines
A01 warning on constantly. Just appeared dont know to fix
Have you checked there is no water in the base of the machine?
There is likely a float in there which activates a microswitch turning on the drain pump.
You could try tilting the machine through 45 degrees and see if any water comes out.
It could take only a cupful of water inside the base of the machine to trigger the safety switch
Dec 27, 2007 | Indesit 24 in. DE73 Evolution...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
