Question about The Health & Beauty
I have dream dazzle styling head and the hair has gone matted is there anything i can do to make it good again
I am 50 years old with long hair that dries frizzy so i have to straighten it, but i want to go short, what style would suit my frizzy prone hair please
I understand your hair type as mine is the same way. I would suggest shoulder length cut with long layers and a side swept bang. Frizzy hair will stay frizzy until you either put product in it or you use a big round brush when blow drying. My favorite time saver after washing my hair is to put a dime size portion of hair oil into your palms and rub together and then run your palms over the top layer of your hair. Blow hair dry. And here's the quick style part. Get a set of velcro hair rollers in the largest and medium size you can find. Use the largest rollers on the top part of the head and medium for bottom layers. Using the hair dryer blow the heat on the curlers for about 15 seconds each. Turn the dryer to a cool setting and blow across each curler again. Remove the curlers and brush out and style. Your hair will be smooth and have body. I use the curlers also on days i don't wash my hair. I just roll the top crown using about 3 rollers to get body on top. I have found the 2 inch rollers work well to give body without curl and also smooth the hair. This is so much faster than using a curling iron or flat iron all over.
Jan 30, 2015 | Health & Beauty
Tip
Hair Care Tips: General A healthy lifestyle will mean healthier hair for you....
Hair Care Tips: General<br />A healthy lifestyle will mean healthier hair for you. Excessive stress, smoking, not exercising and not eating nutritiously are not healthy for your hair. <br /><br />Get enough sleep. <br /><br />Hair Products (Gel, mouse, hair spary...)<br />Avoid using hair styling products with alcohol which dries out hair. <br /><br />Avoid puting hair styling products directly on your scalp, if you put it on your scalp you'll clog the pores on your head. <br /><br />Swimming<br />Before entering a pool, wet your hair so your hair will soak up the initial water instead of the chlorinated water. <br /><br />When swimming where a cap to protect your hair from chlorinated water, if you choose not to wear a cap make sure you shampoo and condition your hair right after you are done swimming. <br /><br />Drying<br />Hot air can be damaging to your hair so when using a hair dryer use the cool setting. <br /><br />Don't leave the blowdryer in one spot for more than a few seconds, keep it moving and at a good distance away from your hair. <br /><br />To speed up the drying process, pat your hair dry with a towell and let the remaining moisture in your hair dry naturally. <br /><br />Gently use your fingers or a pick to untangle any knots while your hair is drying. <br /><br />
on Nov 23, 2010 | Health & Beauty
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
What does texturizing mean when it comes to hairstyles? My hairdresser friend said that my stylist should be texturizing my hair and I have no idea what that means.
Texturizing hair is a method used to remove some of the excess bulk in hair styles. Shorter hairs are cut throughout the head which creates space in between the strands which adds a more airy lighter look to an overly full head of hair.
Ask your stylist to show you some examples in a magazine.
Feb 14, 2013 | Health & Beauty
My hair is super fine. It just looks like its about to fall out. Are there any hair styles that will help make my hair look fuller?
Thinning and fine hair can be really frustrating as there are lots of hair styles that really only look good on long, thick hair.
Stick to shorter styles. You might be tempted to grow it longer to make it look more, but a shorter style that is all one length is more likely to add body to the cut. A few carefully added layers can help but don't get carried away.
2005 5.7 hemi #1 spark plug sounds like air by pass and boot blows out
Interior toys
Now bypass auto supplies market, greatly small high-quality goods complete a person dazzling, one sort of solar doll let an individual fondle admiringly. Modelling are: with earplugs little XiongHuang his visit listen to music, lovestruck QQ doll image kiss the other, green small seedling two leaf there fan ah fan... Get hold of a place on the vehicle, that is certainly so conspicuous, lovely. Along with these solar doll outside, and glued on the instrument desk spring toys, in the rear from the car seat or for the cotton material figures, etc. Stop looking forward to or traffic annoyed, have a look at these small toys, the climate will likely be relaxed many. Is decorated the master of the automobile, but decorated the owner's dream.
Leather seats
Modified leather seats is car upgrade project in more simple common, plenty of original for cloth cover seat cars, can by changing leather seats to realize along with the same brand luxury car comparable built-in effect. This can be the original car interior change is bigger, beautiful effect was more obvious way to have fun playing the a part of beautiful. Replace leather seats can help the car equipped with class, add luster for the car. Naturally, leather seats and never easily hidden dirt, cooling fast, simple to clean and action.
Ground rubber mat
New car to stick the earth rubber, mat quite a bit of owner's first choice, after all, a layer of ground rubber can prevent dirt and dirt with your car. Quality to glue, although effectively steer clear of the dust, can also increase the risk for dirt is difficult infiltration carpet. Choose novel style, color beautiful form special land glue or mat obviously more can start to play the role of beautiful car.
Aug 21, 2012 | 2000 Dodge Durango
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
May 31, 2011 | Conair Health & Beauty
I dream that i took a bath..then i had a hair falling...what does it means?
To dream that you are taking a bath, signifies a cleansing of your outer and inner self. You are washing away the difficult times. This dream may also be symbolic of ridding yourself of old ideas, notions, opinions, and other negativities. Your dream may be pointing toward forgiveness and letting go.
To dream that you are going bald, suggests a lack of self-esteem or worries about getting older. Alternatively, baldness symbolizes humility, purity, and personal sacrifice. You are at a stage in your life where you are confident in fully exposing yourself.
Mar 08, 2011 | Computers & Internet
I have relaxed hair and I am about to go to the Caribbean on vacation for 1 week. I am thinking of having my hair braided so that I would not have to style it every morning. However, I also plan to spend a...
My girls love having their hair braided during this time, so the fuss of styling each day is gone. All three of us have perms. Since I braid their hair myself, I am careful not to braid so tight that I pull their brains out, which we all know is frequently done. I don't like strained, tight and consistent pulling on permed hair! The hair is already in a fragile enough state. I do recommend a professional if you are going to wear braids on vacation, as you'll want them pretty the whole time. Tell them what you're after, then sit back and clench your teeth if your scalp is as tender as mine! Girl, swim to your hearts desire while you're gone. Just be sure to use a anti-chlorine shampoo and good conditioner whenever you're finished for the day. I also recommends "ion Anti-Chlorine Swimmer's Shampoo". Follow the directions on the label. Hope it's available in your area, if not, ask a reputable beauty supply store for a substitute. Just be sure it removes chlorine from the hair and nothing else! This works great for me and mine, so I hope it will be just as great for you. You can also wash your hair while your braids are in of course. Ask your stylist how best to do this. Be sure to use a good anti-chlorine shampoo first. My girls and I often follow this shampooing with a good moisturizing shampoo, then an excellent conditioner. Their are lots of different brands available. I caution you to use the anti-chlorine shampoo whenever swimming is over for that day. We simply cannot go to bed with chlorine in our permed hair! I am not telling you anything I have not tried on myself and my girls. Our hair grows with swimming, so we know this works. Good luck, have great fun, and do everything I wouldn't do, plus some!!!
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Health & Beauty Logo
29 people viewed this question
Top The Health & Beauty Experts
Don A
Don A
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
