Question about Navman GPS
My easy 255 Navman only shows a blue screen saver after I mistakenly clicked demo in menu. How do I get menu back when switching on?
Chintu-KPV
  • 202 Answers
SOURCE: problem with teacher netop
this occurs when u have keys not matching between client and server... Please aviod using spurious serials and stop software piracy (if u r a victim)
Try some free software for the same purpose
Have a nice day.
Posted on Jan 26, 2008
SOURCE: Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Posted on Jul 09, 2008
SOURCE: Navman S300T stuck in demo mode.
just discovered that the probleb with display mode is because the maps are no longer loaded? yet on pc the maps are present? anyone know how to sort this out?
Posted on Jun 26, 2009
  • 25 Answers
SOURCE: i can see the menu screen but after half an hour
if it is 2 red rings it is overheating. moved it to a place that is not confined. or get an after market fan add on. if it is more than 2 rings, you need to send it in for repair
Posted on Oct 07, 2009
  • 825 Answers
SOURCE: i tried to chang the screen saver but it keeps going back to the bubble screen saver
I think you are using the Windows7 Starter edition. This version does not allows you to customize settings.
Please clarify if you have any doubt.
Posted on Feb 06, 2012
How do I fix the navman f45 from being only in demo mode?
Demo mode is switched of in settings under the menu called "about".
Nov 20, 2014 | Navman GPS
Navman s80 locked in shop demo mode, how do I get it back to normal
Demo is selected in settings / about menu.
Deselect demo mode from here.
Oct 10, 2014 | Navman Mio Navman S80 GPS Executive Soft...
My navman f35 keeps going into demonstration mode while traveling to a chosen set destination ..about every 10 minutes i have to keep resetting it which is impossible when i am driving it is dangerous
The problem is that from the settings, the demo mode is set as a kind of screen saver option, you need to go to the menu, settings and turn it off. It is indeed very dangerous trying to set your gps while driving so You need to park your car somewhere safe, then you go to the menu and turn off the demo mode, after turning it off, it will stop showing the demo mode.
Hope this piece of information was helpful
Dec 21, 2010 | GPS
Backlight not working on my Navman Pin 570
On the main menu (Start-- Win Logo) go to settings. Then go to system at the bottom of the screen. Tap on Power. At the very bottom of the screen in small print go to "Adjust Backlight settings to conserve power". Click on "backlight" in blue print.
Apr 16, 2009 | Navman PiN 570 GPS Receiver
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
GET MY COMPUTER BACK TO DEMO SCREENSAVER
Click on Start/Settings/Control Panel, then select "Display", then select the "Screen Saver" tab on top. In the "Screen Saver" section, use the drop down menu to select the screen saver you want (you can click on the "Preview" button to the right to see what each screen saver looks like before applying it)
Aug 09, 2008 | Acer Computers & Internet
Navman S reset
Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
  • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
  • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
  • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
  • Tutorial – run the tutorial that appears at startup.
  • Shop Demo--runs a demo so you can see the Navman S50 in action.
Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
Jul 23, 2008 | GPS
Navman
Jul 23, 2008 | GPS
Navman S50
My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
Dec 30, 2007 | Audio Players & Recorders
Demo wont cancel on Navman S30
If PIN feature installed, just turn PIN off and this should bypass allowing the demo to continue. Then go to preferences from the menu, and stop the shop demonstration.
Dec 22, 2007 | Navman iCN 330 GPS Receiver
GPS Logo
32 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
