My needs some repairs so that I am able to continue livivng in it
Kitchen floors, cabinets, and sink. Need small laundry room repairs, the house underpinned and the hotwater heater replaced and relocated. outside of houses needs paining and some walls repaired. and a roof
Therinnaiguy
  • 1420 Answers
SOURCE: need to move the unit by dismantling
Remove the two screws on the side trim. Remove the two top screws from the filter panel. Reach behind the heater and pull the sock down on the vent pipe. unclip the two clamps holding the vent pipe together. Remove the plastic elbow off of the vent termination. Slide the heater to the left to slide the vent pipe off of the vent termination. Remove the gas line after shutting the gas off.
Posted on Dec 30, 2008
  • 10865 Answers
SOURCE: ELECTRIC FOR OUTSIDE BLOWER
Any time you are going to put an electrical circuit outdoors, you must by the electrical code, have that circuit ground fault protected. You can do this in one of two ways. The cheaper way is to place a GFCI outlet in the circuit between the power source and the outdoor blower. The pricey way is to change the circuit breaker for that circuit to a GFCI breaker. Doing that would make the entire circuit GFCI protected.
Please mark this answer as a fixya!
Posted on Mar 09, 2009
  • 74 Answers
SOURCE: Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Posted on Apr 28, 2009
SOURCE: What size exhaust pipe is needed for downdraft?
I found the answer on the "managemyhome" website. There is a 'manuals' tab that you click on. Then just type in the model number and then you are in business. Thanks for this website. I like it
Posted on Sep 04, 2009
  • 10865 Answers
SOURCE: i need a repair kit for a cracked silgranit sink
Hello., Yes definitely. Go to any home depot or hardware store and have one of the clerks show you the assortment of adhesives that will work on your problem. The fast drying clear resins and the one minute clear epoxy both work great.
Posted on Feb 03, 2010
Brand new house. I put laminated vinyle in the basment . Do i have to put my bathroom sink (cabinet) over the floor or put the sink firt right on the concrete floor and go aroud with the laminated
It is always recommended that you install flooring under all devices. This is so that if you ever decide to update the sink base that you won't have issues with the flooring not covering entirely. But there is no NEED to do so.
Jul 12, 2016 | Building Materials
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
Just bought it and want to know how to fill it with water
gee think you need to hook the water lines up on the back of it
Jun 16, 2015 | Washing Machines
Foul Odor & Occasional Leak
Looks like you were suffering thru the same thing we have in our house - did you ever get a solution to this? I was wondering if some of your vent pipes were cracked or partially clogged, especially where you had that plumbing access hole in the wall. Hope you've got this fixed already, since plumbing companies usually charge about $350 to run those smoke tests to find and pinpoint problems, and it doesn't always work. Buzzie
Feb 07, 2014 | Plumbing
Best sources for renovations of Fort Myers Homes?
The best sources for renovations of Fort Myers Homes is that renovating the house is that big undertaking of the small space of the aesthetic spaces of the kitchen surface it need to be well integrated with the micro kitchens very uniquely of the rooms cabinet things.
Dec 19, 2012 | Audio Players & Recorders
Why does my washing machine (located in the laundry room) back up into my kitchen sink
I it hard to believe that a sink full of water will drain "freely" if the washing machine machine water will not. My suspect is that a minor blockage exists in the main sewer drain line-AFTER the point of connection of the washer. A cleanout point probably exists near that point of connection. Please use it to clear the line.
Jan 05, 2012 | Dishwashers
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
My LSR7233EZO was draining on the floor, flooding my laundry room and kitchen, during the rinse cycle. What would cause this situation?
check the outlet tube for cracks or a loose clamp, also make sure the tube is draining in the sink or drain tube and has not slipped out.
Nov 09, 2009 | Washing Machines
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
