List ofteaching methods - Computers & Internet
How to unlock the google blue screen off my ZTE Z799VL majesty pro
Please either speak to Google or list your 'any other method out there on the internet'...
Nov 14, 2017 | Google Computers & Internet
Tip
How to Transfer Files to Your iPhone or iPad For Newbies
<span> <p>A friend of mine recently called me, frustrated, because he couldn't figure out how to get PDFs on his iPad. While it's actually a very simple operation once you know how to do it, it's not something that's very obvious to people who are new to iOS (as many iPad users are). Here's a look at the simplest method of transferring files to an iDevice for those who don't yet know how to do it.<br /> <p>The video above will walk you through the process visually, but here are the basic steps you need to follow:<br /> <ol> <li>Connect your iPhone, iPod touch, or iPad to iTunes. (You can let it sync if you want, but this isn't necessary.)</li> <li>Click on your device in the list on the left side of iTunes. (It'll be under the "DEVICES" header.)</li> <li>Click the "Apps" tab up on top in the main panel of iTunes.</li> <li>Scroll down to the bottom where you'll find a "File Transfer" section with a list of apps. From that list, choose an app you want to transfer a file to.</li> <li>Onto the (probably empty) space to the right of the apps list, drag in the file you want to transfer. You can also click "Add..." to browse for the file and choose it. As soon as you've chosen the file, it will transfer to your device. You'll see the progress at the top of the iTunes window. When it's done you can disconnect and your file will be on your device.</li></ol> <p>Some apps provide additional ways to transfer files that you may prefer, but this is the most straightforward method and it works for every app that supports files. If you'd prefer to transfer over Wi-Fi (or another method), check the app to see if it has other methods. These methods vary from app to app, but most provide instructions so you can learn how to use the various transfer methods. They're worth exploring if you prefer to avoid connecting your device to your computer every time you want to transfer a file.<br /></span>
on May 31, 2011 | Apple iPad (16 GB) WiFi Tablet PC
I would like to install netflix tv on my Television
How to Watch Netflix on TV
There are multiple methods. The link above list several such and the steps to follow for each methods.
Oct 14, 2017 | Computers & Internet
What is the URC-383 Universal Remote Code for Yamaha DVD S700
0281,0274,0210. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 27, 2016 | Yamaha Televison & Video
Driver download
If your computer does not recognize the USB device, first try method 1 to work around this issue. Method 1: Initiate recognition of the USB device by using Device Manager To initiate recognition of the USB device by using Device Manager, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Click to select your computer as the location for the scan. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method resolves the issue, you are finished. If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub Note If you perform the following procedure, you may also reduce the battery life on a portable computer. Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Expand Universal Serial Bus controllers. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed. Click the Power Management tab. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK. Repeat steps 3 through 6 for each USB Root Hub in the list. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method does not resolve the issue, go to method 3. Method 3: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device. If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus Back to the top ' Give Feedback
Nov 11, 2013 | Targus AMW05US Mouse
Error Loading Casino List. The Casino list may be
tolong di respon,kata sandi poker pro ID saya
Aug 20, 2013 | Zynga Texas HoldEm Poker
Some USB that are attach to my pc are not recognized.
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
  4. Close the Device Manager window.
If this method does not resolve the issue, go to method 2. uparrow.gifBack to the top Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3. uparrow.gifBack to the top Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Aug 14, 2011 | Computers & Internet
Gateway 310 s won't recognize a cd
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
Unblock contacts on reject list
Step 1: Open Settings menu
Step 2: Open Applications Settings
Step 3: Open Call
Step 4: Open All Calls
Step 5: Open Auto Reject
Step 6: Reject list and remove from list.
Sep 23, 2010 | Samsung B3410 Cell Phone
Steganography
u can find it from websites by google .java: embed
which gives list of websites that are enabled
Mar 12, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
