Question about The Office Equipment & Supplies
Error message 654 on polar 66 guillotine Error reads: 'no position counter impulses' acknowledge '654' machine stopped straight after making a cut and not going onto the next programmed cut.
3 Suggested Answers
erdnasetab
SOURCE: hello we have a polar guillotine
Hi.
Its caused by the clutch disc binding on the shaft. Usually a strip down and clean up sorts the fault.
07808 901184
Andre Bates
Independent Polar guillotine engineeer
Posted on Feb 20, 2013
  • 44971 Answers
SOURCE: Polar 115EM,1987 guillotine
The machine may not handle compressed board well. If it works well with othe stock, the answer may be to stop trying to cut it. I know with my manual paper cutters some material does not cut well.
Posted on Nov 15, 2013
Power cut error
go to the manufactures website and download a user manual its normally free and read the section on trouble shooting guide eric
Jan 02, 2018 | Washing Machines
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
Nov 15, 2013 | Kitchen Appliances - Others
Polar 115 EM ,1987 guillotine
Compressed Board? Probably dulling the blade, so after a few cuts, it starts to drag the stock. Try a fresh blade or moving the material to the other side of the cutter.. If you watch the gauges and pressures all look good, I can think of no other problem. I'm not a tech, just a long time user. If any air might be getting in, you would most likely see fluid spraying out.
Safety bolt locked on polar guillotine
Bolt locks are pretty cheap and don't usually cost more than $10. You can get a new one.
Nov 14, 2012 | Cars & Trucks
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error Message: Rollers dirty; Clean rollers; Push 'Reset Counter'
There's a user utility that installs with the driver & other software. The counters for cleaning & replacement are in that.
Apr 09, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
