Question about Sewing Machines
The controller, operated by my foot, does not function! What to do?
  • Sewing Machines Master
  • 11,200 Answers
There is something wrong with the controller that could need a part replaced or you can purchase a replacement control unit.
Posted on Aug 10, 2017
The pedal on my pfaff 7550 has stopped working. Can you please help.
It could be the machine, itself, or the foot control that is defective. If you can, check the machine with a different foot control to see if that works. If so, then you can purchase a replacement foot control (just look online for Make Model parts). If the other foot control does not make the machine operate, then you know it is probably a machine issue.
Jan 29, 2018 | PfaFF Sewing Machines
No power going into the foot pedal, when i step on half bubble nothing happens
The foot controls with the air function tend to fail, usually because they develop a leak. You may be able to get a replacement from your dealer.
Sep 10, 2017 | Sewing Machines
What is smart pedal foot control for Bernina? I have a Patchwork Edition 140 and needle stop down should be controlled by pedal according to shop. I don't understand.
The foot control you are talking about will activate the needle down function on your machine. You need to press down on your heel on the foot control. This was the precursor to the automatic needle up/down option that is found on newer sewing machines that will automatically stop with the needle in the down position.
Mar 12, 2017 | Sewing Machines
Foot pedal does not operate needle
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
Oct 29, 2015 | Singer 3116 Simple
Fast sewing on its on without pedal
Hello Tammy.
There is a mal-function in either the sewing machine or the foot control, or the junction. It would be good to find out which one is faulty. If the power and foot control leads are joined, there is no easy way to distinguish the location of the problem.
If your foot control and power leads are separate, disconnect the foot control and check if machine continues to sew by itself. If yes, the problem is with the machine. If no, the foot control is either stuck or malfunctioning. In either case it is best to take it to your local qualified technician.
May 02, 2015 | Sewing Machines
What does E5 means
On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
Need more detailed information about Brother XL 2600i ?
Sep 30, 2012 | Singer 6180 Sewing Machine
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
My foot pedal doesn't seem to work when I push it down
Probably needs a new foot control. Bring the machine and the foot control to a shop, they can test it to see if it is the control, the wires from the control to the machine, or something else.
The control and wiring are sold separately, the control is often cheaper than the wires from the control to the machine, don't throw anything away until you have someone look at it first!
They will remove the non functional foot control from the wiring and put a new one on. A new foot control is not expensive.
Feb 09, 2010 | Elna Sewing Machines
Foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
May 24, 2009 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
