Question about In Office Equipment & Supplies
Missing or failed printhead or ink system failure displayed in control panel
SOURCE: Ink System Failure Series C7280 Error 0xc18a0001
Reset the printer. Thanks.
Posted on Jun 14, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
SOURCE: Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
Posted on Sep 15, 2009
SOURCE: Ink system failure
Open the printer as if to replace an ink cartridge. On the print head there is a black plastic arm about 2 inches long. Re-connect this with the white cog wheel so that the protruding part is in the center of the black arm. Close lid, power on and job done.
Posted on Nov 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: ink system failure on photosmart c5380 0xc19a0036
Hi
Thanks for using FixYa. To resolvethe issue of display of error Oxc19a0036 you’ll need to reset the printer andto reset it please follow the step-by-step procedure on the link---
Howto Reset Photo Smart Printers
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Posted on Jan 26, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
HP c6180 Won't print magenta dark or light
Regarding your question about the HP 02 Light Magenta/Dark Magenta printing issue (lack of print output), are you observing the error message(s): "R6025M, R6031M" and/or "INK SYSTEM HAS FAILED" with your HP Photosmart C6180 printer? Based on your problem description, this could be poor connectivity between the ink cartridge and the printer's PRINTHEAD or the PRINTHEAD has reached END-OF-LIFE. Unfortunately this particular printer writing system is now ~13 years old, and depending on your print volume, the PRINTHEAD may have suffered permanent electrical degradation*
Check chip condition, pictured here on our Inkjet411 support site (2nd picture circled in red): http://inkjet411.com/?page_id=1372
However to be sure, you may want to get a new HP 02 (OEM) ink cartridge to completely rule the refilled cartridge out of the equation as cause of failure. Otherwise, proceed to our suggested diagnostic steps below.
If one of the steps cannot be performed please go to the next one. If you do not have one of the buttons go to the next suggested solution.
Solution One
A. NON KEYPAD PRINTER MODELS: http://inkjet411.com/?page_id=2377
1. Get the unit into the "Support Menu" by following the steps below:
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release the "OK" button.
Display should say "Support" and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says "System Configuration Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. Retest the printer.
B. KEYPAD EQUIPPED PRINTER MODELS: http://inkjet411.com/?page_id=2391
Steps:
1. Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
Then
1.
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
C. - Press and release in sequence the "1", "2" and "3" buttons.
Screen should say "support" R0631M
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO XXXXX" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. Retest the printer.
Solution Two
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Solution Three
If both solutions ones and two fail it means your waste ink absorber is full and needs to be replaced. The absorber is a small sponge like pad inside the machine underneath the ink cartridge cradle. It sits underneath the cradle when the cradle is all the way to the right inside the machine. To fix this problem the pad needs to be replaced - see video: https://www.youtube.com/watch?v=km3szjM49ZQ
Solution Four
If all the other solutions fail it means the permanent PRINTHEAD inside the machine has likely failed; unfortunately the PRINTHEAD is not replaceable in this printer model*
*The HP 02 ink series printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 6 ink cartridges and then firing the ink droplets onto the paper) - the HP 02 PRINTHEAD typically has a maximum life of approximately 40,000 pages (~15,000 page average). Unfortunately, the permanent PRINTHEAD is not replaceable. http://inkjet411.com/?page_id=2054
CAUTION: Be advised, the use of HP 02 compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD damage due to incompatible ink formulations. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 02 or HP 02XL original/genuine ink cartridges is only suggested!
HP 02/02XL Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=SGA692TUWTc
If, after performing the suggested procedures above, you still have not reached resolution please let us know. For any additional questions please contact us directly: Inkjet411help@gmail.com
If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Inkjet411 Team Member
Aug 19, 2014 | Office Equipment & Supplies
Error code 03B363E2
An error message that starts with '0x...' or 'C2...' that might include the text 'Problem with Printhead,' 'Problem with Printer,' or 'Ink System Failure' displays on the printer control panel.
Jan 23, 2014 | HP DeskJet 5550 InkJet Printer
Blue ink won't print
The cyan print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 20, 2013 | HP Officejet Pro 8500 Wireless All-In-One...
Not printing correct colors all come out light brown or pink
For severe HP OJ 6500/6500A/7000 print quality/missing color issues, or incorrect color output, there could be an air bubble in the ink cartridge(s), an air gap between cartridge and PRINTHEAD, or a portion of the PRINTHEAD is dry (quite common), so you should first perform a CLEAN PRINTHEAD procedure from your printer control panel.
It is first suggested you print the SELF TEST or PRINT QUALITY REPORT (under TOOLS menu) to aid in identifying which color is causing the issue. Check that cartridge or cartridges to ensure they have plenty of ink inside.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the CLEAN PRINTHEAD procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and thoroughly flush all ink ports for 2-3 minutes...thoroughly dry printhead prior to re-installing. Retest. For complete instructions refer to video here: http://inkjet411.com/?page_id=2412
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (while Officejet 6500/6500/7000 printer PRINTHEADS are rated for an estimated 15,000 pages, the average consumer may only see up to a 10,000 printed page throughput) and may require replacement. A severe failure of the PRINTHEAD is typically accompanied by error messages such as INCOMPATIBLE PRINTHEAD, REPLACE PRINTHEAD or INK SYSTEM FAILURE. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead electrical performance, activate the Tap 41 diagnostic test, (i.e. Pen Status: Pen OK).....for printer model instructions please visit: http://inkjet411.com/?page_id=1813
To solve other HP920 ink-series printer/printing related issues please visit http://www.inkjet411.com
Apr 01, 2013 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 e709n print quality poor even after replacing print head
For severe print quality/missing color issues there could be an air bubble/air gaps in the printer ink lines or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest.
For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
Hp 920xl black error
These cartridges can dry up. You can take a tissue and make an impression on the tissue. This will tell you if the cartridge is dryed up or not
Sep 24, 2012 | HP 920XL Black High-Capacity Inkjet...
Ink system failure, everything was fine, i put new ink in just like i have many times before and now it won't print anything, it keeps telling me ink system failure on the monitor
This error usually means you are at the end of the life on the printhead or the printhead assembly has a defect causing it to stop working. You can try removing all of the cartridges with the machine on. once they have all been removed unplug the power cord from the socket (be sure printer is still on!) wait about 30sec-1min. then plug back in. the display will Read out of ink install and an icon for each missing color. Reinstall all cartridges and close cover. it will take a minute or 2 for it to cycle and prime the ink. The display should read ink Sysytem Failure, power down machine. Press Power button to shut down, leave for another 30sec. and then turn back on. If the error displays again you will have to contact HP for in warranty service or replacement options. Note: if you are out of Warranty it is a good idea to shop for a new printer via Costco, Walmart, or an Office Supply Store, it will save you $$$
(a friend had this issue and they were going to sell her a new printer for $30 more than staples plus shipping!)
Feb 18, 2011 | HP Photosmart C7280 Printer
Replaced empty black ink cartridge, wont print black ink even after cleaning and aligning the printheads
The head of your printer cartrige (black) are not detected by the printer because it was damage and need to be replace. So that no more black ink could print anyway.
May 26, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
35 people viewed this question
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
