Question about The Computers & Internet
I want to have a large time display instead of a tiny one on the top right corner
5 Suggested Answers
rhuzmarhuz
  • 167 Answers
SOURCE: How to display the date on my home screen
just press the menu botton'
go to setting
sellect initial set-up
and select time and date.
you can now set the time and date of your fone...
Posted on Jan 07, 2008
SOURCE: Number 2 In top right hand corner
That doesn't do it...
Physically unplug your cable box for at least one minute. This reboots your digital cable box and the number should be gone. It has nothing to do with your television.
I hope this helps!
Posted on Jan 30, 2009
  • 4 Answers
SOURCE: window is too large for screen
well, you have to resize the monitor rsolution like make it bigger or smaller until it is fixed.
Posted on Jun 15, 2009
  • 10 Answers
SOURCE: large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Posted on Sep 13, 2009
Laptop LCD monitor (needs advance help) I have a Dell m5010 laptop that started to display small vertical lines from that bottom left corner going up to the top right corner. I plugged the laptop up to...
Try a different resolution in the monitor to see if that helps. You can do this by right clicking on the desktop and changing the resolution within the screen properties. If that does not make a difference, try searching for updated display drivers either through the laptop manufacturers website or its possible you have a bad controller board for the LCD screen.
Nov 25, 2014 | Computers & Internet
Need date displayed, not just edit it, on the bottom corner of my computer
This is for windows 7,
1 - Right click on the taskbar and select properties
2 - Under the 'Taskbar' tab you'll see the 'Notification area', click the Customize button
3 - Click on "Turn system icons on or off"
4 - The first item should be clock. Select on instead of off.
5 - Click ok.
Mar 15, 2013 | Dell Computers & Internet
Touchpad not working
There's a tiny orange light near the upper left corner of the touchpad to the left of the touchpad. If that is lit, you may only have to tap the upper left hand corner of the touchpad a couple of times to get it to go out. and start the touchpad working.
Barring that, see if the synaptics driver is installed. Go to "Control Panel," change the "view" in the upper right hand corner to "large icons," and see if "Synaptics Touchpad V8.1" is listed.
If not, go to "Control Panel," locate device manager and click (with a usb mouse) "mice and other pointing devices," click "Synaptics PS/2 Port Touchpad," and check to see if it says, "device is working properly." If not or if it still doesn't work, click the driver tab, and click "update driver."
Dec 08, 2012 | HP elitebook 8760w
HP Elitebook 2530p switches on but no display
Hello!
Just a quick one or two at the moment. Have to locate the problem then figure the fix sooooo..
1. Please refer to the photo: Note the 'hands', one at the top right and the other at the bottom right of the screen. With the power on and the computer in the normal ready to use mode....
What I suggest you do is hold the bottom right corner firmly, keeping it relatively immovable while, at the same time, GENTLY, and NOT completely, SLOWLY start bringing the top left corner down toward the bottom right corner, actually moving the top barely an eighth of an inch, flexing just a tiny bit...
If the display flickers then, hopefully, it is a loose display cable, usually a flat one that lies under the keyboard and need only be adjusted. a tedious but very inexpensive solution.
Another quick, albeit unlikely fault to check is your battery. I know, I know, it's so obvious but I have to ask: Have you tried using the computer from a DIFFERENT wall outlet, better still, at a buds house?
Let's get these two out of the way before moving on? Let me know! I'll look into recalls, frequent problems, etc....
Jimm
Nov 21, 2012 | HP EliteBook 2530p Notebook
Canon eos d40 makes a long noise before it takes a picture
It sounds as though you have activated one of the timers. On the LCD display on top of the camera look in the bottom right-hand corner of the display and see if there is a symbol that looks a bit like a one-handed clock (the timer symbol). If so, press the AF-Drive button on top of the camera and rotate the large, circular selector dial on the back of the camera until that symbol goes away. Now the camera should shoot normally.
Jan 29, 2012 | Canon EOS 40D Digital Camera
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Nintendo DS The Legend Of Zelda
First of all, this crest is VERY difficult to draw correctly
But have you ever tried to draw the hourglass instead?
Sep 26, 2008 | Nintendo The Legend of Zelda: Phantom...
When I switch my windows XP Home Edition on instead of the usual gradual build up to Desk Top & icon programmes etc. I get the usual large black screen but instead of the windows motif appearing I get...
The results you are seeing are actually from the monitor itself. It's telling you the vertical and horizontal sync frequencies to help you troubleshoot your lack of display.
You'd usually see this happen when someone has set the resolution too high, and the monitor just can't handle it.
Power up, and keep tapping F8 until you get a Windows boot menu. Choose "safe mode", let it boot to windows. Go to display properties, and then settings. The slider for the resolution will now be right down. (left-most). Click it once, so that the apply button becomes valid. Hit apply and let it restart.
You should now boot to Windows normally, but with a very low resolution. Go back to display settings and bump it up one step at a time, using the apply button. (which will revert back one step if you don't hit "yes" within 20 seconds).
That way, you can find a resolution that looks right, but isn't too high for your screen.
Aug 22, 2008 | Packard Bell Computers & Internet
go to setting
Jan 05, 2008 | Motorola Mobility RAZR V3
PIONEER DEH P 5450
turn it off press the time display button located in top left corner then time will display,then pres and hold top right corner button until 12:00 flashes first the 12 will use your channel buttons on right side to scroll up the the time then when you get the correct time set press the clock display button again in top left corner of face plate!merry christmas!!!
Dec 12, 2007 | Car Audio & Video
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
