Question about Midea Heating & Cooling
Midea air conditioner E9 error code for the display shows.. what is the problem.. please give me a answer
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: On Power up the error code E9 displays with a continuous beep
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Posted on Sep 12, 2010
  • 1243 Answers
SOURCE: Midea floor standing air conditioner displaying error code E6.Please what does it mean and possible solutions.
Google says:
E6 Room temperature or evaporator temperature sensor open or short circuit
The prescribed cure:
Check to make sure the room temperature sensor is connected and reads the correct resistance value. If the sensor operates correctly, replace the control board.
This unit most likely employs a NTC thermistor as a thermometer sensor. Common resistance values are 1k ohms and 10k ohms at room temperature. As the temperature goes up, the sensor decreases in resistance.
The sensing element could look like any of the above, but with portable comfort units, they usually look like the bottom row of encapsulated and cabled assemblies.
Posted on Feb 09, 2015
sloooo44
  • 156 Answers
SOURCE: I have a Friedrich QuietMaster Electronic SS12J30D Air Conditioner and I got an E9 error, what does it mean?
E9 is the code for heat pump failure. If you can locate your reset button, reset the unit. If it doesn't work, you might want to consider getting another unit
Posted on Aug 09, 2016
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
My midea aircon is showing F3 code?
Display = E2
Malfunction or Protection = Communication error between indoor units and outdoor unit.
This is the meaning of the error code. If you need any more AC Cleaning & Repair help contact the professionals.
Apr 07, 2015 | Midea Heating & Cooling
Google says:
Feb 09, 2015 | Midea Heating & Cooling
New Midea Air Conditioner system 3, does not seem to get cold air. Mode is on Cool and fan speed increase. Temperature at 20 degree.
More info needed. Is this a one-piece unit or a mini-split? Model number, any error codes, etc. More info will help
Jan 03, 2015 | Midea Heating & Cooling
Error code e 9
E9 indicates Voltage error. Check the power.
Feb 01, 2014 | Midea Heating & Cooling
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
Mar 13, 2013 | Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Heating & Cooling Logo
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
