Question about Sony Cyber-shot DSC-W80 Digital Camera
The lens goes in and out and then says "turn camera off and on"
It was recentluy dropped in the sand; is there any way to clean out the defective lens?
  • 300 Answers
Hi!
It sounds like that the focus is stuck because of the sand. Contact your local Sony service center or if they ask too much, you can contact me at toms.safranovs@gmail.com
I work in a Sony service center and repair these every day.
Tom
Posted on Jul 28, 2009
I dropped this camera accidently in the sand at the beach.I've cleaned it out the best I can but the Lens evidently still has sand particles in it. when I turn on the power it reads "Lens...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 10, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Focusing Problem
hi, if you can open your camera and remove the lens unit assy(just be carefull to the flat cable its easy to be broken) you can clean by yourself just to remove the sand goes inside of the lens unit and also to the gear.make it sure you need to use magnifying glass to see the small pc of sand .some time the sand goes to the gear that cause of malfunction or not rotate properly and also the focus gear have also sand that why the focus is bad.if you can't do this just bring to service center and request for cleaning.
thank you
Jun 19, 2010 | Casio Exilim Card EX-S100 Digital Camera
When I turn on my camera the lens goes in and out then the screen display says "Turn the power off and on again"
you have sand on lens zoom. Is not a easy job to clean that sand. you will need some skills.
May 31, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Digital camera dropped lens-opened on the beach and now the lense will not open properly
Hi
There is sand in your lens and it is jamming upthe gears. One grain of sand will cause the lens to fail! You can try to take the lens apart and clean out the sand but it's not easy and an opened lens usually never focuses exactly right again.
Look for a defective camera online that has a good lens but broken LCD or some other problem and fix that one using yours as parts or have yours fixed with a new lens.
We can do a new lens install for you for about $80-90 I believe. If we can help please let us know!
Thomas D
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Dropped camera in the sand, and now it comes on and goes off
use a vacume to get any grit out. DO NOT BLOW THE CAM WITH AIR!! you will send more sand inside the unit. usually its inside the lens housing.
Jun 03, 2009 | Cameras
The Beach
You may want to call Olympus Customer Service and discuss their repair process and procedures for sending the camera in to have the lens assembly cleaned. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 09, 2009 | Olympus FE-190 Digital Camera
Lens error restart camera but it just switches off same problem. dings and turns it self off. Canon PowerShot® SD850 IS Digital Camera. Lens cover is only partially closed. Possibly sand in mechanism...
Hi
Your lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Oct 05, 2008 | Canon PowerShot SD850 IS Digital Camera
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Camera
clean off the lens and any other open areas when you dropped it..
Aug 08, 2008 | Cameras
Dropped fe- 230 camera in sand..spazzing out..help ASAP please
Borrow a friends camera or buy another.
The motorized lens assembly is contaminated, and
your only recourse is to replace the entire assembly.
It has very close tolerances and even replacing it is no guarantee that all the sand particles could be cleaned out of the camera body.
Sorry. No easy fix this time.
Regards Paul
May 30, 2008 | Olympus FE-230 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
143 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
