My Devant LED TV has an upside down video display, after replacing the main board. What should I do?
Devant 40GL510 LED TV Display Upside Down
  • 2427 Answers
SOURCE: monitor displays everything upside down
On the monitor thereshould be some buttons, like menu a let arrowa right arrow etc. Simply press menu and look for the screen rotation setting(many monitors are different and it might take some fiddling around to actually find it) and then set it to the setting you want. There is aslo a reset option, you can use that if you choose and this will restore it to the defaults..
Posted on Jan 19, 2008
  • 6 Answers
Posted on Jan 22, 2008
  • 16 Answers
SOURCE: Display is completely upside down
You can often press CTRL + ALT + UP/DOWN to rotate the screen if you have an integrated Intel Graphics card. Or it could be CTRL + SHIFT + UP/DOWN. One or the other.
Posted on Dec 15, 2008
  • 7752 Answers
SOURCE: motorola razr display is upside down
the lcd needs to be replaced take the phone to a repair store to have this done.
Posted on Dec 28, 2008
  • 566 Answers
SOURCE: Upside down display
I have read that to invert the LCD-screen you just flip the polarisation-plate (the plastic film that sits over the LCD display) 180º, that is, upside down.
Did you or someone opened your calculator? He might have reassembled it wrong. Or was it a prank?
If that was not the case, your best change is to reset the calculator and see if it solves your problem.
To manually reset your graphing calculator:
  • Remove all AAA batteries.
  • Remove the back up lithium battery.
  • Leave the unit empty for 5 to 10 minutes.
  • After the 5 to 10 minutes, place all the batteries back into the graphing calculator.
This process should restore the graphing calculator to the factory settings.
Good Luck!
Posted on Sep 10, 2009
Replaced control board on my Element ELDFT406 43" now picture is upside down. Please help I've been thru menu with no success.
Select source on your remote and enter 7343 that brings up the factory menu. Go down to other setting , the setting "scaler output" should be set to "Normal". This setting flips the display. Thats all that there is to it, this is really common for this to happen when replacing the main menu in any brand Funai TV
Dec 26, 2017 | Element Televison & Video
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
I have a Samsung 40 led smart tv... Model number UN40D6000SF.. The problem I'm having is when the boot logo is upside down tv will flash on n off. What is wrong with it??
Samsung say you should try the factory reset option.
If that doesn't work it could be a fault on the main board. Sometimes this happens when boards are replaced.
There is also a service mode that allows you to flip the main screen. You can find how to access that by searching YouTube with the words "Samsung TV picture upside down".
Try the other options first though.
Apr 04, 2017 | Samsung Televison & Video
My display on Samsung 60 tv is upside down after main board replacement
Please check to see that all pcb cables are put back in their sockets correctly. I am afraid if you continue using it that way you could damage the new board again. Let me know if you get stuck.
Nov 19, 2016 | Samsung Televison & Video
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Jul 13, 2016 | RCA Televison & Video
How do I fix display show upside down. TCL LED TV Model: L24T2100
Feb 20, 2015 | Televison & Video
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Oct 30, 2014 | RCA 42LB45RQ 42 in. LCD HDTV
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
Jun 07, 2012 | Televison & Video
The text on the printer's display shows up backwards, upside down, and when you scroll thru it, things get all cluttered. The printer operates just fine, its just impossible to scroll thru the menus on...
If your 6360 has a blank display, garbled characters, inverted, upside down, or backwards display the control panel is bad and must be replaced.
Here's a video to replace it. It's very easy and takes about a minute.
Apr 30, 2010 | Xerox Phaser 6360 Laser Printer
Check in the setting of your webcameras control panel and see if there is an option for changing the view.
Jul 23, 2008 | A4tech PK5
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
