Question about Lands Phones
DOes the vetch DECT6.0 Corded-Cordless phone come with an adaptor?
SOURCE: Need an instruction manual for Ativa D5772 corded phone
I now have a .pdf file of the owners manual for this phone system. It took me over a month to get it from the Ativa customer service dept. and 3 calls. BUT I can email it to you if you wish, understand it's a 7MB .pdf file.
Posted on Feb 21, 2008
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
cnavarro
  • 2460 Answers
SOURCE: Is there a Panasonic cordless kx-t7730
The chances are, if you have CID you don't have to worry....the first call after 3am will fix it. If not, programming from extension 101 and 000 will fix it.
Any industry standard cordless phone will work on a Panasonic system...are you plugging it into a system phone port with the sytem phone? If you are trying to make both work on the same port, you have to tell the system that. Program option 610 in a TA series or 600 in a TDA series will set a Paralleled phone so both can work.
If you don't know how to get into System programming, your installer or dealer should.
Carl
Posted on Nov 02, 2008
  • 11 Answers
SOURCE: My cordless phone in my restaurant is finally had
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Posted on Jan 11, 2011
  • 1196 Answers
SOURCE: VTECH Cordless phones are not
I will suggest you reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem. If that did not fix the problem, let me know.
Posted on Feb 07, 2011
How can I open the base of vetch cordless phone and check internal power connections
The screws that hold such an item together are usually hidden under the rubber feet. Prize them out with a narrow blade screwdriver. Unlikely that anything will have moved inside, but you might find a fuse. Problems with cordless phones is usually the handset batteries failing as they are nearly always charging.
May 31, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
Tip
Motorola L402C Manual Download
Download Motorola L402C Cordless / Corded Phone Manual
Have you misplaced your Motorola L402C Cordless / Corded Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Motorola L402C Cordless / Corded Phone Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Motorola L402C Cordless / Corded Phone instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Lands Phones
Tip
Follow this link
I hope that helps.
on May 09, 2010 | Motorola Mobility L402C Corded Phone
How to answer aphone call
For the Corded L402C you just pick up the handset to Answer. For the Cordless you can push the talk button to answer.
Cordless/Corded Phones
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Corded/Cordless Phone email)
Mark
Motorola Support
http://www.motorola.com/on/demandware.static/Sites-Site/Sites-Motorola_US-Library/default/v1335985434876/Products/Cordless-and-Corded-Phones/L402C/Motorola_L402C_UserGuide-English.pdf?version=1,336,482,725,000
Aug 28, 2014 | Motorola Mobility L402C DECT 6.0...
I can make calls but why can"t i receive calls on my vtech cs6649-2 phone?
Check out your manual for troubleshooting. Google the phone and model # with your question. I have a guess the ringer is turned OFF or wiring is not correct. Good luck.
Jan 14, 2018 | Vtech CS6649-2 Silver Cordless Phone DECT...
How do I place call on hold/mute for vetch 5.8ghz cordless phone
Enter the model of your VTech 5.8GHz system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Oct 04, 2013 | Vtech 5.8GHz Analog Cordless Phone
Need to hook up vetch cordless phone to my internet modem/router
Hi, this phone is analog so it can only be connected to a standard phone line, if your router or modem has a FXS connector (phone jack) with an active land line service, you could connect it there.
Aug 02, 2013 | Vtech CS6719-16 Cordless Phone with Caller...
No dial tone after an electrical storm . I had to replace the AC adaptor. Everything else works.
Having to replace a power adapter indicates a pretty severe power surge that could easily have destroyed your Cordless Phone Base station delicate electronics!
But to ensure that it is not a faulty telephone line, plug a working corded telephone directly to the phone wall jacket and see if you get a dial tone.
Hope it helps: let me know how you go.
Jan 13, 2010 | Uniden Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
